I've just shelled out £220 for a BSM slip-on can for my TA 650, and the damn thing doesn't fit as well as it should. The collector pipe slips on to the collector box and bolts on to a bracket used by the original exhaust. The can itself bolts onto the collector pipe and should be fixed to another bolt hole with a thin metal strap - trouble is that once screwed onto the collector pipe, the can is jutting out at a slight angle and touching the side panel. Tightening the strap fully is impossible without placing excessive strain on the join between the can and the collector pipe - not a good idea.![]()
I guess I could attempt a bodge and try bending the bracket on the collector pipe so that it brings the can a little closer to the frame and away from the side panel.![]()
My question to the panel is this: is this kind of situation to be expected with aftermarket cans - even model specific ones, which this one is supposed to be?![]()
Ithangew.
