Results 1 to 6 of 6
Thread: Those tank protectors .......
    mightdomaybe is offline Senior Member
    Feb 2007
    Worcestershire
    the carbon ones which you fix to the back of the tank to protect it from kit / zip scratches etc ? Do they 'glue' on ? or is there some other semi-mystical fixative which sticks them on ?? & once on, can they be removed without causing any damage to the tank ??? or are they on for good ???
    Xander's Avatar
    Jul 2006
    Lichfield
    Re: Those tank protectors .......
    mine are glued on.. it was just a big sticker... Dont know if they are there for good or not.. (i did not put them on in the first place).. but i reckon that it will be hard to get em off
    Dee Duble Yuh's Avatar
    South Wales, UK
    They are held on by a voodoo spell. If you want to remove them without damaging the tank you have to sell your soul. HTH.
    DW (Dave)
    "Let's ride motorcycles!"
    Feb 2007
    Worcestershire
    Quote Originally Posted by Dee Duble Yuh View Post
    Hmm.....I think that's probably about right ....it's not for the TA, there's a Honda one on there already & that's ok, functional, & suits the times, but I have this 20 year old VFR which is about as good a 20 year old bike as you're likley to see, unrestored, & I'm tempted to put one on but not if I can't remove it without leaving a mark.
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    they can be removed, i had a black one on my blue tank when i bought it and didn't like it so with a long blast of the wifes hairdryeron fuul heat( unbeknown to her!!) it eventually softened up and peeled off, swiftly to be replaced by a clear one that appears tank color and much less noticeable.
    Xander's Avatar
    Jul 2006
    Lichfield
    Quote Originally Posted by mightdomaybe View Post
    GOOD to know!!!
  1. headlight protectors
    Last Post: 25-07-06, 11:20 AM
  2. Back protectors
    By peterb in forum Chatter
    Last Post: 29-05-06, 04:33 PM
  3. Back Protectors
    By Slimie in forum Chatter
    Last Post: 25-03-06, 10:42 PM
  4. fork protectors ?
    By 24ftlb in forum Transalp
    Last Post: 04-11-05, 09:47 AM
