Results 1 to 7 of 7
Thread: Baglux Tank Bag fitting question
    Steve C's Avatar
    England - landed in Yorkshire
    Just checking to see if anyone has one of these Baglux tank bags - fitting instructions were usefully omitted but I've followed my nose (anyone that's met me will know it's easy enough to find ) and it's on OK so far as I can tell...
    I am unsure about the placement of the side/bottom hooks one toward the bottom of each side with a stretchy rubber strap and a flat plastic hook on the end to grab hold of the bottom edge of the tank.
    Question is: Did you have to remove the trim that runs along the bottom of your tank to fit it?
    Mine's an AT, BTW, but I expect it's the same fitting on all trail style bikes?
    Steve
    !Boris!
    !Boris!!Boris!
    Mutley's Avatar
    May 2004
    Top of the hill
    Re: Baglux Tank Bag fitting question
    If you've got as far as fitting the bottom clips, you're nearly there Steve. I stuck a bit of insulation tape on to the tank as well as the plastic strip.
    It might be Baglux that have altered the fittings as I was sure the clips fastened onto my previous AT easier, and they have altered the shape of the bag.
    Steve C's Avatar
    Thanks Shel
    Just realised I've been vague as usual. The side straps are on the tank COVER.
    Hence the trying to get the hooks under the bottom edge of the tank. Sorry about that.
    The bag, on the other hand, seems very Heath Robinson Some strange plastic rotating loops on the tank cover... are they supposed to match up with something on the bag do you know? I have loosened a couple of straps so that a D ring on each side do get within range, but it seems a bit, well, made up on the spur of the moment
    !Boris!
    !Boris!!Boris!
    SammoJim's Avatar
    SammoJim is offline Older but Still no Wiser!
    Hereford
    Just fitted a Baglux cover on my AT and yes, I had to take off the rubber strips along the bottom of the tank
    As for the bags. Be careful as there only a couple of bags that fit the Twin.
    I made this mistake and bought a map pocket that is too long. This is the standard size. The bag I just ordered to fit is a "City Trail"
    I think the "Dzeta" is the only other one that fits. Worth checking with Baglux first
    Hope this helps
    Steve C's Avatar
    Quote Originally Posted by SammoJim View Post
    Hope this helps
    Thanks for that - nice to have it confirmed.
    Eeek, bag. I ordered something called Medea, but what arrived was a Minea.
    tried it on the bike - it seems to fit - albeit a bit Heath Robinson.
    Think I'll check it out with Demon Tweaks - the folks I got it from.
    Thanks for your help!
    Steve
    !Boris!
    !Boris!!Boris!
    SammoJim's Avatar
    Hereford
    No probs
    Glad to be of some help
    The distance from the center of the clips at the back to the (very easy to break!) rotating clips at the front is about 250mm on the tank cover.
    On the (incorrect) map pocket it is adjustable, but the least I can butcher it down to is about 380mm.
    Check these out if it helps:
    http://www.bagster.com/en/moto/catal...p?id_moto=2517
    http://www.baglux.co.uk/productinfo.php?code=844
    Steve C's Avatar
    Thanks SammoJim - I might be OK though because when I tried it on, it wasn't too long.
    Now Boris the bike's got all his clothes off again because his fuel pump failed as I set off for work - at least I hadn't reached the motorway!
    So I'll check the bag again once the new one's in and I'm moving agin
    !Boris!
    !Boris!!Boris!
  1. baglux tank bag
    By eammonj in forum Africa Twin
    Last Post: 05-01-09, 09:20 PM
  2. Baglux tank cover
    By Austin in forum Transalp
    Last Post: 17-06-07, 10:49 AM
  3. Which Baglux tank bag?
    By coldstart in forum Africa Twin
    Last Post: 05-02-06, 01:41 PM
  4. Has anyone got a Baglux tank bag?
    By Simon in forum Chatter
    Last Post: 26-11-05, 06:54 PM
