Results 1 to 10 of 14
Thread: Torque Wrench.
    Cabby's Avatar
    Cabby is offline SOTGATT
    London/Surrey
    Torque Wrench.
    Just been using me new..(cheap ? ..£30) Torque wrench.
    PROBLEM: Everything in Haynes is in Nm....
    Guess what I've got..
    YUP !!!!! Ft/lb
    ...........Kg/m
    NO Nm......ANYWAY......
    There's a crude conversion table with it...So I've been dividing Nm's by
    1.356 (or 1.536....not near it at the mo' ) to give me the correct Ft/lbs.
    I just want to double check with more competent people on here that I'm
    right......consequences too much to risk.
    If I'm right I'll fill in a few more examples in the table so I don't have to
    keep calculating.
    Robster's Avatar
    Feb 2005
    Shepperton
    Re: Torque Wrench.
    What are you doing to your Tranny then?
    Is it Gnarly yet?!
    Cabby's Avatar
    London/Surrey
    Re: Torque Wrench.
    Quote Originally Posted by Robster View Post
    Is it Gnarly yet?!
    Hey Rob...
    Just got back from Redhill with full on Gnarlies fitted + new tubes ...heavy
    duty front...didn't have HD rear...Should I slime them? ....Took 'em
    loose so I could clean 'em and have a poke around while they're off...bit
    of hammerite on frame and stuff.....anything else I should do while it's up
    on the "short plank"
    Tony's Avatar
    Tony is offline Member
    Feb 2007
    North Nottinghamshire
    Re: Torque Wrench.
    Try here:-
    http://www.onlineconversion.com/torque.htm
    Tony
    1.356 is as near as you need to get.
    Robster's Avatar
    Feb 2005
    Shepperton
    Re: Torque Wrench.
    Coool! Did you go for the TKC's then?
    You'll have fun getting used to the feeling of "falling" into corners, but half an hours ride just trusting them and you'll be loving it and using that feeling to your advantage.
    Urrrm I'm not really Mr Technical, but I'd probably take the opportunity to give everything a good clean and lube up, if it's anything like mine then it'll all be really dry. Grease up your spindles (Ooooh Matron!) and maybe drop the oil and filter while you're at it.
    Cabby's Avatar
    London/Surrey
    Re: Torque Wrench.
    Quote Originally Posted by Tony View Post
    Try here:-
    Tony
    Thanks Tony...Just put it in my Favourites....(Not that I'll remember that
    later)
    Cabby's Avatar
    London/Surrey
    Re: Torque Wrench.
    Yup!!!
    Tkc's.....I'll sort it tomorrow and go see the folks at the coast sap...
    Lumiya's Avatar
    Ziost
    Re: Torque Wrench.
    Tony you beat me to it, amazing what google will find!!
    Kymmy
    Re: Torque Wrench.
    I put all the most used torque settings, valve gaps, sparkplug numbers, oil capacities and tyre pressures on a few little cards which are laminated, hole punched and hang on the same hook in the garage as my 17mm spanners. I have the ones for my bikes and car on the same ring. As you can see they are pretty grimy and have been well used. The front card for the AT set dates back to my first RD04. As you can see I can't spell crankcase.
    It's rare I get a manual out to look for torque settings. The reason some torques are in Newton metres and some in foot pounds is because I use different torque wrenches for different things and they are oin different units.
    Lord Vader's Avatar
    Basildon in deepest Essex :-)
    Re: Torque Wrench.
    Wow how cool is that,yen got a reminder thingy
    They call him "Ze Quiet one"
  1. Replies: 4
    Last Post: 08-07-07, 03:22 PM
  2. Max Torque.... When?
    By Pigglet in forum Africa Twin
    Last Post: 14-05-07, 12:19 PM
  3. TT bars & engine bolts & torque...and....
    By mightdomaybe in forum Transalp
    Last Post: 11-05-07, 12:22 AM
  4. Torque setting...
    By faantjie in forum Mechanical Advice
    Last Post: 14-09-06, 07:35 PM
  5. Torque wrench setting??
    By JohnW in forum Transalp
    Last Post: 06-04-05, 02:05 PM
