Brake problem solved ...
Results 1 to 2 of 2
Thread: Brake problem solved ...
    Jochen is offline Member
    Nov 2006
    Oud-Beijerland, Netherlands
    Smile Brake problem solved ...
    Hello fellow @-ers,
    Ever since I bought my bike I had some strange braking problems.
    Whenever I would brake my lever would seize (I thinks that's the word, meaning it would not go any further) a little, and therefore brake only a little. When I would squeeze harder it would eventually shoot through the "obstruction" but offcourse cause sudden extra hard braking. This is a not desired effect
    But now the reason for this effect .... The head of the master cylinder was corroded. It had some rough edges on it and since the lever presses on it with great force, it could not overcome the edges unless pressing a lot harder and shooting over it.
    Cleaned it this weekend and greased it up. Also greased up the lever pen, made al whole lot of difference. I can brake with 1 finger now
    Just wanted to share,
    Jochen.
    xrv_jim's Avatar
    Jul 2004
    Cumbria
    Re: Brake problem solved ...
    There's always a good feeling that comes from tracking down and fixing these problems
    Jim
    '85 XL600R - Rebuild Thread
    '95 R1100GS
  1. problem solved,thank god.
    By churches67 in forum Dominator / FMX
    Last Post: 19-06-07, 07:31 PM
  2. slight problem - solved i think
    By Simon in forum Africa Twin
    Last Post: 05-02-07, 08:21 AM
  3. Brake Caliper Problem
    By miggy in forum Africa Twin
    Last Post: 21-02-05, 03:50 PM
  4. Handling problem solved?
    Last Post: 07-12-04, 10:01 AM
  5. Rear Brake Problem RD04
    Last Post: 03-07-04, 09:31 PM
