My bikes been in bits for weeks now while I've been tidying things up and repainting etc. and I'm about ready to start putting it back together again (thank god! - it's dragged on for far too long).
I've just got one of those stainless allen bolt kits from ebay and planning to use stainnless nuts and bolts for as much as I can get away with.
I know these aren't as strong as regular steel bolts and shouldn't be used for anywhere there's high stress, but not quite sure exactly what I can use them for and what I should avoid using them for.
Does anyone have any pointers. I figured all the parts that are just hanging plastic (chain guard, fairing fixings, water bottle etc) will be OK, but not sure if I can get away with using them for much more than that. Has anyone used stainless bolts for anything heavier duty than this, and what things should I absolutely be avoiding them for (I know engine mounting bolts and any major frame bolts are going to be a no-no but not sure about things like radiator mountings etc where there's going to be some weight on them but not a great deal?).
The other thing I'm not sure about is the other bolts that need to be replaced (subframe bolts etc) I've taken off and removed all the rust with a wire brush. They're looking nice and clean and rust free at the moment and my plan was to put those back on. Is this a good idea or are they going to rust up again very quickly. Not sure if they'll have had some sort of coating on originally to prevent them rusting that'll be gone now and if it's really the best idea to get a set of high tensile bolts to replace all those as well? Or could I get away with just putting the originals back now they've been cleaned up?
