Results 1 to 8 of 8
Thread: Oxford heated grips - new switch
    Austin's Avatar
    GARSTANG
    I was talking to a techie guy on the Oxford stand atteh NEC about the new switch I had ordered for my heated grips. I asked if it was true that they auto-turned off after a period if the engine wasn't running. Its true. They have a sensor to detect when voltage drops below 11.5v and then switches off. Even better if when you turn them on the lights flash at you to warn if the battery is near 11.5volts.
    New switch fitted this weekend
    Chad's Avatar
    wickford,essex
    Re: Oxford heated grips - new switch
    ive fitted some new grips today and got to say the new switch is ver good
    Slimjim is offline Member
    Oct 2006
    London
    Yes I bought a set with the new style switch just after they were released. It's a good improvement over the old one because with the low voltage protection I didn't need to wire up a relay. Plenty warm enough too, the lowest setting is normally enough for me!
    Austin's Avatar
    GARSTANG
    oh, forgot to say he told me the grips MUST be wired direct to the battery as a relay could reduce the voltage too much so that they either never turn on or turn off prematurely!!!
    Cie's Avatar
    Cie
    Cie is offline Advanced riding bore
    Amesbury, Wilts
    I've had the new switch fitter for some time now and I have to say I preferred the old one.
    The switch stayed switched on when the bike was off, and so came back on when the bike was started. It was easier to operate with a gloved hand whilst riding, and I don't think that the plastic switch cover will last that long. It's the same kind of membrane that they used to put on remote controls, which have all peeled in my house.
    Bah humbug!
    '08 KTM 990 Adventure S
    Cie's Avatar
    Cie
    Amesbury, Wilts
    Errrr, mine are through a relay and work just fine, soooo, they seem to work both ways
    McVicar Guest
    Got mine fitted through a relay as I didn't trust the switch to turn off and I know I'll leave them on. They are working fine and toasty.
    McFly's Avatar
    McFly is offline Senior Member
    Aug 2007
    London
    the new style switch/controller works well but the buttons are an arse with gloves on. Just have to kinda mash your finger in the general area and wait to see if the light comes on!
  1. Oxford Heated Grips vs Motrax Headed Grips
    By Wold Rider in forum Africa Twin
    Last Post: 13-12-08, 09:58 PM
  2. oxford heated grips
    By Xander in forum Mechanical Advice
    Last Post: 26-11-07, 05:03 PM
  3. Oxford hot grips - switch corrosion?
    By sjk6000 in forum Africa Twin
    Last Post: 30-08-07, 12:42 PM
  4. Heated Grips... Oxford
    Last Post: 29-11-06, 06:02 PM
  5. Oxford heated grips
    By Patrick in forum Transalp
    Last Post: 03-03-06, 12:04 AM
