Results 1 to 10 of 11
Thread: Oil & Air Filters
    Annette's Avatar
    Hampshire
    Oil & Air Filters
    What is everyone's preference for oil and air filters? I've just put a Champion oil filter on my @.
    Do you tend to use Honda manufactured filters or after market pattern ones?
    Lumiya's Avatar
    Ziost
    Re: Oil & Air Filters
    Moved to biketech
    As for filters you'll find that most filters are made by the same company and just repackaged/badged per brand. Oil is another matter as there's so much to choose from, as long as you have the correct grade and don;t mix synth/non-synth (as it turns it into sludge) then you should be fine. though there is some arguement about using non-bike oils in bikes as the additives normally don;t work well with wet clutches.
    Kymmy
    FatFergie's Avatar
    Mar 2006
    I use pattern filters, can't remember the last brand I used but it wasn't really any cheaper than the honda oem. I tend to use motul semi synth (and only bike specific) for no other reason than I used the two stroke version for years and never had to replace main bearings, rings or pistons when all around me my contemporaries on similar bikes were pushing them. Not very logical but ........
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    Hi Annette
    I normally use genuine oil filters, I have installed a K&N air filter which is expensive to buy approx£45 main advantage is never having to replace. just clean& re-oil.
    BIG D's Avatar
    BIG D is offline Senior Member
    MORAY
    I have used Honda and also Champion filters and use a good quality semi-synthetic oil, Mal how is the K&N performing and did you have to rejet your bike I am still thinking about trying one on my 600
    BIG D.
    wheeliebin's Avatar
    N/A
    I'll only use Honda and HiFlo (heard Hiflo make the K&N one).
    I bunch Fram, Champion and Filtex altogether at the bottom end of the quality scale.
    This guy had a look at how different filters are constructed, there is a surpising difference between the brands.
    http://www.tobycreek.org/oil_filters/
    mal's Avatar
    mal
    Aug 2004
    GLASGOW
    Hello Don,
    No you don't have to re-jet, only difference I noticed after fitting was slight increase in induction noise
    BIG D's Avatar
    MORAY
    Thanks for the info Mal I think I will try a K&N air filter I also found Wheelybins Item interesting about oil filters.
    BIG D.
    Lumiya's Avatar
    Ziost
    Quote Originally Posted by mal View Post
    Hello Don,
    AT's tend to run slightly rich so adding a K&N airfilter probably won;t do any harm. Though as with any fuel/air/exhaust change to any bike I would for the week or two afterwards keep an eye on the plug color as it's the best guide (without the need for a dyno and gas analyser) as to what the mixture is like
    http://www.nightrider.com/biketech/spkplghnbook.htm has a good guide to plug colors but there are lots more websites about that have the same info.
    Kymmy
    BIG D's Avatar
    MORAY
    Usefull advice Kymmy thanks best to [Air] on the side of caution.
  1. K&N Filters
    By BIG D in forum Transalp
    Last Post: 16-11-09, 09:31 PM
  2. best oil and filters
    By cookingfat in forum Transalp
    Last Post: 10-12-07, 05:10 PM
  3. filters
    By dean in forum Africa Twin
    Last Post: 21-05-07, 07:45 PM
  4. Pod filters ??
    By atgreg in forum Africa Twin
    Last Post: 31-03-07, 10:55 AM
  5. K&N Filters
    By garry in forum Africa Twin
    Last Post: 20-01-05, 10:16 AM
