Results 1 to 9 of 9
Thread: sand riding
    xrewen is offline Junior Member
    Jan 2008
    Aviemore, Highlands
    Smile sand riding
    I'm off to Morocco with my xr. Does anyone have any advice on chain lube (do'nt laugh), the little sand riding i've done before i used a dry chain but this seems a little harsh for the drive system when i've always been used to keeping the chain well oiled. Happy new year!
    nomad's Avatar
    nomad is offline chicken chaser
    horwich, bolton, lancs
    Re: sand riding
    not done much sand riding other than southport and talaker beach in wales but have always been told to use a dry chain for continuous use on sand
    if you have a well oiled chain and it mixes with sand it becomes like a grinding paste-not good for any chain
    don't know of any alternative other than having a spare chain for sand riding,if there is someone with desert riding experience will be along in a minute
    Tarka's Avatar
    Sep 2006
    Wirral, England.
    Re: sand riding
    I used to sand race and you DON`T WANT TO BE USING CHAIN LUBE !!!
    Clean the chain after EVERY section of sand riding.
    If you`re a novice at sand riding,bias your weight rearwards and relax your fore arms...allow the bars a fair bit of free play,as a death grip and tense arms will lead to a loss of the front end.
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    Re: sand riding
    Quote Originally Posted by Tarka View Post
    Why am I not suprised by this...........
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    Apr 2007
    East Anglia-ish
    Re: sand riding
    yup dry chain ! take a paint brush and brush your chain off when you stop shift your weight back wear good boots and let some air out of your tyres this will increase your forgivness margin and help with cheesy grins
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    May 2006
    Re: sand riding
    yep run dry, buy the best quality you can afford (x link lasts the longest) or work on buying the cheapest and binning and replacing it regularly.
    Gotham's Avatar
    Gotham is offline adventurer
    Tallinn
    Re: sand riding
    Or try this:
    http://www.profiproducts.com/profidrylube.html
    I used it one season - it works
    May 2006
    Re: sand riding
    yep seen a few people try that suff, but then i know somebody that also uses pledge!.... another favourite is wd40 but this can on some chains screw up the o or x rings due to the solvent. Yamaha tend to run a stock chain with no o or x links and then lite lube (not sure exactly sure what with but its like wd40) every now and then, life span is pritty short though!.. think the Baja boys run RK chain and wax also heard a few good comments on cheap chains with Milltec1.
    Gromit3528's Avatar
    Gromit3528 is offline Barking
    Apr 2007
    Northants
    Re: sand riding
    It depends if you are actually racing on sand where you may get frequently buried in the stuff up to the axles. I can see the sense in keeping it dry.
    My experience of touring in sandy areas with only occasional forays into deeper sand suggests that when you want to play its best to shut down any thing like a Scott oiler that you may have fitted and wipe off any excess oil. Having had your fun in the sand wipe off as much muck as you can and then crank the scottoiler right round to prime and go for a thrash on tarmac for a few miles. Your chain will be amazingly clean and (well oiled) when you stop. You might have something resembling a quatermass experiment lurking on your bashplate where all the crap has been flung off the gearbox sprocket, but your chain will still be good for many thousands of miles which is what you need when touring.
  1. How do you do it on sand?
    By Oldie in forum Dominator / FMX
    Last Post: 02-10-07, 05:09 PM
  2. sand jump ... looks fun
    By SteveWilko in forum Chatter
    Last Post: 20-08-07, 08:11 PM
  3. Little sand on the XR
    By Pete Rock in forum Ride Reports and Pictures
    Last Post: 16-07-07, 11:16 PM
  4. Tarmac, mud, sand
    Last Post: 23-04-07, 05:42 PM
  5. Oz sand ride
    By Zonkelnut in forum Transalp
    Last Post: 14-07-06, 10:23 PM
