Results 1 to 5 of 5
Thread: Givi Monokey Pannier Rack Fittings
    slanty's Avatar
    slanty is offline Senior Member
    Apr 2008
    London
    Hi All,
    I'm seriously considering making a set of panniers like the ones in this tutorial.
    My @ has Givi Monokey racks fitted and I was thinking I'd try to make the panniers hook onto these brackets but I have never seen how the panniers connect to these brackets.
    If someone has Givi Monokey panniers and some spare time, could you please post up some detailed pictures of the fittings and how they connect up?
    If anyone has any suggestions about how I could make brackets for the rack then that'd be great too
    Cheers,
    Slanty
    1gear1brake's Avatar
    Portland, Dorset
    Re: Givi Monokey Pannier Rack Fittings
    Touratech sell pannier mount brackets which will work on your Givi rack. However they will set you back around £38 plus postage for each pannier!
    Rather than pay Touratech, I decided to do it:
    I made my own brackets to fit a Givi rack out of some scrap bits that I found lying around at work plus about £4 on stainless bolts.
    First I cut out a piece of marine ply (roughly the same thickness as the width of the rack tube - 15mm I think) to the shape of the inside of the frame. Then I gave it some coats of Yacht varnish and left it to dry. Then I fixed it to the back of the pannier with 5 bolts - I put a thin steel plate on the inside of the pannier too for extra strength.
    I attatched an aluminium plate onto the bottom of the wood which forms the bottom part of the bracket. I had to shim this out slightly to ensure a snug fit. The two top brackets can be tightened/loosened using wing nuts on the inside of the pannier to mount or remove it.
    That's probably as clear as mud so here are the pictures.
    Hope this helps
    slanty's Avatar
    Apr 2008
    London
    Hey 1gear1brake,
    That's exactly the kind of thing I was looking for
    Thanks a million mate!
    When I'm making them I may drop you a couple of questions if that's ok.
    Thanks again
    Slanty
    Dee Duble Yuh's Avatar
    South Wales, UK
    This guy used some U channel to go over the top rail. He'd used a spring-loaded eyebolt but your rack may already have a tab protruding upwards. Cut a slot in the U channel so it goes straight over! You'll then need some another U channel or a pair of pucks for the lower part of the case.
    DW (Dave)
    "Let's ride motorcycles!"
    Portland, Dorset
    Quote Originally Posted by slanty View Post
    Slanty
    Happy to help.
  1. Givi tubular pannier rack TA
    By kenn in forum Transalp
    Last Post: 12-08-09, 12:27 PM
  2. Pannier rack
    By peterb in forum Africa Twin
    Last Post: 20-06-06, 10:15 PM
  3. Givi Wingrack 2 monokey
    By barrowboy in forum Transalp
    Last Post: 18-05-06, 11:34 AM
