Re: big feet & gear lever, help please.
The gear lever should be easy, just undo the pinch bolt, remove it, then slide the gear lever off the splines and refit it one spline further round. Try it for size with your boots and if happy refit and tighten the pinch bolt.
Depending on your bike, there should be an adjuster for the rear brake lever. The AT has a lock nut and a threaded rod, loosen the lock nut then use a spanner to turn the threaded rod by it's hexagon shaped part. It's imediately obvious as you turn which way the lever is going. When happy you just retighten the lock nut.
