Results 1 to 10 of 15
Thread: Car oil
    ACP's Avatar
    ACP
    ACP is offline Junior Member
    Apr 2008
    Christchurch, Dorset
    Car oil
    Hi all,
    I'm just about to service my Transalp for the first time with the help of a friend who is a long time biker and definate Honda man who has previously owned a TA. He used to be a courier and has riden hundreds of thousands of miles and always serviced his own bikes.
    Now he reckons that to save some money that I can use (good quality) car oil instead of motorbike specific stuff.
    He swears by it and claims never to have had any problems from using it but I'm still slightly dubious about doing this so can anyone explain the difference between the two and whether there will be any negative effects on the bike and if its likely to cause any damage or not?
    Thanks...
    Boris's Avatar
    Oct 2006
    Edinburgh, Scotland
    Re: Car oil
    Can't comment on car oil but Gericke do a semi synthetic motorcycle oil for about 12-13 quid for 4 litres. Not having bought car oil for a while I don't know how it compares price wise though.
    I'm on the Safe House List
    Lumiya's Avatar
    Ziost
    Re: Car oil
    Just remember that most car oils are NOT designed to work with a wet clutch and the slip additives in car oils can make the clutches slip...
    But some find it a problem others don't, ASDA even do a 10-40w oil for under a tenner..
    Try it, if it works it works, if not then you've wasted a tenner thought the drained fresh oil will be fine in a car.
    Kymmy
    KirriePete's Avatar
    KirriePete is offline Senior Member
    Land of hills and heather
    Re: Car oil
    Car synth or semi-synth is a definite no-no because of the friction modifiers and associated clutch slip issues - ask me how I know this to be true! When I realised what I'd done I changed the oil out for the most basic stuff I had in my shed - Halfords own brand diesel lube. Worked a treat and I've used it ever since with no problems, if anything she seems to run smoother and doesn't use any oil at all.
    Legal disclaimer - Just my experience, following my advice may end in a grenaded engine (or it may not), either way it ain't my fault!
    You're welcome
    Lumiya's Avatar
    Ziost
    Re: Car oil
    The type of car oil is irrelavant as Mineral, Semi or fully synth all have friction modifiers...
    Bike oil (or any oil designed to work with a wet clutch) simply dont (or don;t have as much)
    Apparently there's another thread going on about diesel oil (Xander PM'd Jen and I about it but although Jen responded I've not had the time to look) and I will say this..
    Diesel oils are just like normal car oils except for one difference and that is the addition of stronger detergents to try to keep the engine cleaner/gunk free...
    Kymmy
    Twosheds's Avatar
    Twosheds is offline Member
    New Forest
    Re: Car oil
    But it is 'Blade' innit!!!....you feeling lucky, ACP?
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Re: Car oil
    I use good quality 'car' oil (usually Duckhams Q) in both my bikes (AT and FJ1200) and have done so with all of other bikes I've had over 25+ years, due to (non) availability of 'bike' oil and pure laziness!
    I've never experienced any problems with clutch slip or anything else oil related for that matter. This isn't a recommendation, just my experience, but I'd have no hesitation in filling an 'alp with 'car' oil.
    Jim
    '95 R1100GS
    '80 XT250
    ACP's Avatar
    ACP
    Apr 2008
    Re: Car oil
    Well I went ahead and filled with Mobil1 10w-40 and all seems fine. Not experiencing any clutch slip... and yes it is 'Blade', Mr C
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    Re: Car oil
    I use a mineral 10/40 car oil in my Alp.It is the old SG spec stuff so doesn't contain friction enhancers.No problems as yet.
    Rust never sleeps
    Ashley M's Avatar
    Ashley M is offline Senior Member
    Apr 2007
    Buckinghamshire
    Re: Car oil
    This is a different question but still oil related I have always used 10w40 and ride my bike a lot off road and do a lot of motorways I was thinking of trying a thicker oil 10w50 as 10w40 seems very thin when my engine does run hot a lot of the time (off road and prolonged motorway) has anybody got any do or don’ts about tying this
