Originally Posted by
harper
I have acquired a 2003 honda clr125 and noticed that the fork seals are leaking and need replacement.
I have removed the forks from the bike, taken off the top cap, drained the oil, removed the bottom allen bolt, removed the damper rod
After looking a varoius articles I understand that the sael are removed by using the stanchion to tap out the seal.
However I can get the thing to shift, I have tried using boiling water but withou any success.
Could anybody advise if there is technique to removing the seal because I am now out of ideas
