Results 1 to 9 of 9
Thread: Rear brake judder - is there a classic?
    fish's Avatar
    fish is offline Member
    Jul 2006
    South Norfolk
    Hi,
    My TA rear brake judders (pumps), varying with speed. The other key symptom is that the outside brake pad is wearing away quickly while the inside is hardly touched.
    I've followed the threads and cleaned everything, copper greased the piston which is moving freely and other stuff. but still it's still the same.
    I suppose the next obvious is a warped disc , but like one of the previous posts said, "discs don't just warp".
    So before I shell out, I just get the feeling that the pads wearing one side and not the other is a Classic symptom of something.
    I was hoping someone would know what that something is?
    Fish the Unbalanced
    It's making me deaf, but I'm not going to stop doing it.
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Rear brake judder - is there a classic?
    Not sure how your calliper is mounted but it sounds like it is stuck and not centralising itself
    It should be free to move side to side in the mounting bolts. Only needs a fraction but it needs to move.
    Discs warp when they are at their hottest and then rapidly cool down ie hard braking, discs red-hot, and hitting a big puddle.
    Lumiya's Avatar
    Ziost
    easiest way of telling of the disk is warped is to put the bike on the centre stand, get someone to very slightly bit by bitslightly pull in the brakes whilst turning the wheel by hand... If warped then the brakes will start to bind on certain sections of the disk and not others
    AlanH's Avatar
    Bristol, UK
    As Snaphappy says, it sounds like the caliper sliding mount has seized so the caliper holds one pad against the disc. This causes the disc to overheat and warp which will then cause the juddering.
    So, time for a new disc, new pads and a caliper strip and rebuild.
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Another thing to check - remove the disc and clean off any crud behind it on the hub. The rear disc on my @ appeared to be warped, but once the hub/disc was cleaned it ran true.
    AlanH's Avatar
    Bristol, UK
    You could always straighten it with a large hammer - the now broken RD04 had that done to its rear disc at some point in its life
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    is it a floating disc? if so then a stone chip might have wedged the disc over in one of the top hat buttons
    fish's Avatar
    Jul 2006
    South Norfolk
    Ok, thanks for the advice.
    Another strip down and clean of the slidey things.
    If that fails, disc off and check for crud and warping.
    New disc on the card...
    Is there a best supplier?
    Fish the Unbalanced
    It's making me deaf, but I not going to stop doing it.
    AlanH's Avatar
    Bristol, UK
    Wemoto are pretty good, as are David Silver Spares.
  1. How to take the rear brake pedal off?
    By LUNLUNZAI in forum Transalp
    Last Post: 08-09-08, 05:48 PM
  2. Sticking rear brake
    By howiezowie in forum Transalp
    Last Post: 18-08-08, 10:11 PM
  3. Brake light delayed from rear brake pedal
    By slanty in forum Africa Twin
    Last Post: 05-06-08, 10:32 AM
  4. Rear Brake !
    By fatowl in forum Transalp
    Last Post: 16-04-08, 02:49 PM
  5. domi hunting judder under 3000rpm
    By kevin nx650 in forum Dominator / FMX
    Last Post: 07-07-07, 10:02 PM
