Results 1 to 10 of 10
Thread: Waterproofness of Garmin Zumo Cradles
    Raven's Avatar
    Raven is offline DILLIGAF
    May 2007
    Dorset, England
    Question Waterproofness of Garmin Zumo Cradles
    According to all of Garmins gumpf they are 100% waterproof, but I'd rather have a proper opinion. So does anyone on here have a Cradle whose connectors have failed due to water corroding them, or are they as waterproof as they say? It just looks too easy for water to get in to it to me.....
    2004 Honda XR125L
    2010 Custom Harley - Davidson
    Whealie's Avatar
    Lewisham, SE London
    Re: Waterproofness of Garmin Zumo Cradles
    Th idea is when you remove the unit you put the little rubber cap over the connectors.
    I did notice a tiny bit of blue on them the other day gave them a quick squirt and a clean up.
    But you can ride in the peeing rain with no problems.
    GoodFoodGuyd Guest
    Quote Originally Posted by Raven View Post
    I can assure you the Garmin mounts are 100% waterproof. I had my Zumo 550 with me the other day on the South Wales Ride Out to "Hell and Back" I think that is where the slag in a bag said we were at one point. The rain was coming at you horizontaly, verticaly and any other direction you so wish to mention. The mounts connections stayed dry. The unit itself stayed bone dry internally of course and it didn't even skip a heart beat due to the torrential rain we encountered. The unit itself just required a wipe over with a damp cloth when I got home. Had I not been confident in the integrity of the unit I would have swiftly removed it and placed it in the back box.
    As Whealie mentioned, you will have to protect the connectors from mild corrosion but I prevent that with just a dab of vaseline on them and always keep the connectors covered when not being used
    Dee Duble Yuh's Avatar
    South Wales, UK
    +1 all of the above. It might be useful to wire the mount via a switch (or relay) so the power isn't on all the time. Mine is permanently powered and if I leave the bike out in the rain and forget to put the cover over the connectors, a little corrosion appears. Not a problem if you do that once or twice, but over time maybe it would damage the coating of the pins.
    Or you could just remember to put the cover on the connectors!
    DW (Dave)
    "Let's ride motorcycles!"
    winxp-master's Avatar
    Jan 2008
    Redcar
    I have a Zumo 550 and don't appear to have any problems with the cradle, the rubber flip over protector seems to do the job when the unit is not mounted.
    The only problem i had with water was it getting into the unit itself (on the Longest Day no less) but Garmin replaced it with a brand new unit inside a week
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Happily, I have not had to use my 550 in the wet very much, but it was happy enough during a 4hr soaking earlier this year at Motorway speeds. It coped better than my boots...
    steveR
    Project Red KMX200
    Raven's Avatar
    May 2007
    Dorset, England
    Excellent, thanks everyone
    2004 Honda XR125L
    stuart's Avatar
    Jan 2008
    lancashire
    however water proof the garmin is ( or is not) it must be a better option than the tomtom
    pete h's Avatar
    pete h is offline Plodder
    Jan 2008
    Yorks/Lancs border country
    I've mentioned the problems we've had at work with the garmins here...
    Zumo - whats it like to use?
    Latest solution: regular squirting with ACF50
    Raven's Avatar
    May 2007
    Dorset, England
    Quote Originally Posted by pete h View Post
    Cheers for posting that link
    2004 Honda XR125L
  1. Dead Garmin Zumo...
    By Dr Green in forum Mechanical Advice
    Last Post: 16-05-09, 11:54 PM
  2. For Sale Garmin Zumo Parts................
    By fw750x in forum For Sale / Wanted
    Last Post: 06-05-08, 11:23 PM
  3. What do you think is best Tomtom rider/Garmin zumo
    By Ashley M in forum Mechanical Advice
    Last Post: 03-05-08, 10:33 AM
  4. Garmin Zumo 400
    By fw750x in forum Mechanical Advice
    Last Post: 22-04-08, 12:09 PM
  5. Garmin Zumo 550 Touratech mount?
    By Cie in forum Mechanical Advice
    Last Post: 03-05-07, 11:10 AM
