Results 1 to 10 of 11
Thread: brake caliper grease
    icenian's Avatar
    Jul 2004
    Votadinia
    when did it become so hard to buy brake caliper grease???
    I want something for brake pad pins, the pins calipers slide on (is there a special name for them?) that'll stop them corroding and seizing. Copper grease doesn't work well.
    I had a tiny tube of something called "brake caliper grease" which was some sort of really expensive synthetic grease that was good. Unfortunately the brand name is illegible, as it lasted me about 10 years and all the printing wore off the tube! I can't find anything that looks like in in local bike shops, car accessrory shops or on the net...
    This stuff...
    http://www.permatex.com/products/Aut..._Lubricant.htm
    looks the business, but only seems to come in big jars that cost about 30 quid. I suppose that's cheaper than the damage I'll suffer if I don't use anything...
    Would rather get something (Permatex or similar product) in a small tube than a half pound jar!
    icenian's Avatar
    Jul 2004
    Votadinia
    Re: brake caliper grease
    p.s. can't find any supplier of GP products "super caliper grease"
    Lord Stig's Avatar
    May 2004
    West Lothian
    Yamaha make their own pretty good stuff, which is odd considering the reputation their calipers have for seizing.... Expensive and comes in a small tube.
    I use 'red rubber grease' on the sliders - it doesn't affect the rubber 'boots' like ordinary stuff does (make them expand) and seems to keep corrosion at bay without melting. Wemoto do it, but they don't have it on their site for some reason...
    Lord Stig's Avatar
    May 2004
    West Lothian
    Oh, if you want some to try I can send you some in a small bag - just PM me...
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    i use a big tub of industrial high temp copper grease. its not the usual coppaslip muck you can get in little tubes its more copper than grease i think, made by fuchs for the aero industry and we got a load delivered to work by mistake so i filched a tub.
    beelag is offline Junior Member
    Aug 2008
    Caithness
    Hi
    I use Fuchs (Makers of Silkoline) Renolit copper paste 500g tub for all the mechanical rubbing bits.
    Try Toolnweld.com for a good price. I have seen it listed as low as £6 and as high as £35 for the same tub.
    For the rubbers/pistons I use Castrol Red Rubber grease 500g tub again I have seen the same wild variation in prices.
    Try
    http://www.tools-supplies.co.uk/red-...500g-434-p.asp
    http://www.nutz4bikes.co.uk/index.ph...vop=100&area=1
    http://www.opieoils.co.uk/p-999-fuch...lastomers.aspx
    Good luck n keep them pistons n calipers amovin
    B
    Kjell Lindberg's Avatar
    Sweden
    Use copper phaste for steel parts only, and use Lithium phaste for alumium high temperature applications
    Dr Green's Avatar
    Dr Green is offline eel be alright, won't er?
    Sunny Devon - put yer yer over yer, see what you can yer....
    I have recently overhauled my front calipers and I too use the 'red rubber grease'
    It is capable of withstanding high temperatures, compatible with natural and synthetic rubber & will not cause cracking or undue swelling.
    Nearly too many bikes...
    j's Avatar
    j
    j is online now SHW'MAE BUTT
    Apr 2006
    if you pop along to your local commercial vehicle spares supplier you can buy tubes of rubber lube or air brake grease stays lubby and dose not affect the seals
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Quote Originally Posted by Kjell Lindberg View Post
    lithium grease is that white stuff isnt it?
  1. Front Brake caliper
    By mal in forum Africa Twin
    Last Post: 01-04-09, 02:10 PM
  2. Front brake caliper
    By russellt in forum Africa Twin
    Last Post: 06-03-08, 10:50 AM
  3. RDO3 Rear Brake Caliper
    Last Post: 24-09-07, 03:43 PM
  4. Rear Brake caliper ...
    Last Post: 03-11-06, 07:43 PM
  5. Brake Caliper Problem
    By miggy in forum Africa Twin
    Last Post: 21-02-05, 04:50 PM
