Results 1 to 3 of 3
Thread: Oxford Hot Grips not working
    v8_simon is offline Member
    Aug 2008
    Sunny Southend in Essex
    Well they just don't do mornings!!!! I wired them up as per instructions turned on fine I used them saturday/sunday no prods, went to turn them on on Monday morning light flashes on then go off Rode a couple of miles no change When I got to work tried again (15miles) no change After 10 mins of bike not running tryed again worked fine 8 hours later turned them on to go home worked fine. This morning same as yesterday Not working till I get in but then work fine!!!!!
    Ideas??????
    Lutin's Avatar
    Galway
    Re: Oxford Hot Grips not working
    Seems like a loose connection to me. Did you disturb the connections to the battery?
    Aug 2008
    At this stage I have it hard wired to the battery
    And there seems to be a real pattern
  1. Oxford Heated Grips vs Motrax Headed Grips
    By Wold Rider in forum Africa Twin
    Last Post: 13-12-08, 09:58 PM
  2. Oxford Hot Grips
    By Martin K in forum Transalp
    Last Post: 28-05-08, 11:39 AM
  3. Oxford heated grips...
    By Grooverider in forum Mechanical Advice
    Last Post: 03-02-08, 11:22 AM
  4. Oxford Hot Grips ; No2
    By Gregger in forum Varadero
    Last Post: 25-10-06, 07:31 PM
  5. Oxford Hot Grips ; No 1
    Last Post: 25-10-06, 07:30 PM
