Results 1 to 7 of 7
Thread: I need some machining work done
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    I'm in need of some machining work done, (eg; making a couple of profiled, round washers/discs a couple of inches in diameter & about 15mm thick), made from steel or Aluminium.
    Anyone able/willing to do the job or know of someone willing to take on smaller jobs, without breaking the bank.
    Thanks, Phil
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: I need some machining work done
    Whats it for Phil?
    setting the machine is what cost the most not the actual production if there are chances of selling off a few you might cut some costs,
    Leigh (& Saltburn!)
    I was just gonna fit an Ohlins rear spring (which I already have) to my Hagon shock, so just a one off job really.
    '02 Transalp
    '98 Transalp
    '91 NC30
    Phoenix's Avatar
    Phoenix is offline Senior Member
    Apr 2004
    Out in the countryside
    Hi piguglyshandydrinker
    you should give Double O a wee shout he has a light engineering company in Bradford. He may be able to do the work himself or will definately know someone who does. failing tht Ive a mate here who does machining.
    Phoenix
    RWB rd07, remus can, dynojet and K&N filter, givi racks, givi hard cases, oxford soft luggage, tourance tires, 12v power socket, oxford heated grips, centre stand, touring scottoiler, very bright headlights.oh yes and a tank cover and bag.
    stuart's Avatar
    Jan 2008
    lancashire
    I have a metalwork lathe in my garage that should cope with the job, I live between Preston and Clitheroe in lancashire,
    Any use to you,
    Bolton, Lancs.
    50mm o/d , what is the i/d ?
    I expect you could find some 50mm o/d tube with suitable wall thickness.
    scaffolding tube is about 50mm o/d, but i suspect too big i/d.
    I know someone your way that may be able to help, i'll PM you his number.
    Leigh (& Saltburn!)
    Ok, thanks for the replies all.
    I'll give Lens mate a bell as he is most local, if I have no luck there I'll be back in touch.
    Thanks again, Phil
    '02 Transalp
    '98 Transalp
    '91 NC30
  1. Machining out of true disc mounting lugs.
    By russh in forum Mechanical Advice
    Last Post: 01-10-08, 02:28 PM
  2. XR400 barrel machining
    By trigsbroom in forum XR
    Last Post: 21-06-08, 09:17 PM
  3. Does this work?
    By YEN_POWELL in forum Ride Reports and Pictures
    Last Post: 22-02-07, 09:29 PM
  4. Do you work in I.T?
    By mgillespie in forum Chatter
    Last Post: 10-05-06, 09:34 AM
  5. Art Work
    By Man up North in forum Chatter
    Last Post: 06-02-06, 07:48 AM
