Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Rugged Roads @ Rack Extension
    1gear1brake's Avatar
    Portland, Dorset
    Seen here. It says can be fitted with or without existing rack. Does that mean it can replace the plastic rack/pillion handles unit? Can anyone tell me how it fits? I'd like to replace the original unit with something a bit more sturdy. The one on my older @ has cracked due to overloading.
    Dylan
    Chad's Avatar
    wickford,essex
    Re: Rugged Roads @ Rack Extension
    Hi dylan the RR rear rack only replaces the black top section of the africatwin rear rack, the silver part with the grab handles remains in place and our rack bolts directly to that
    hope this helps
    chad
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    hi chad, i notice you market it for the AT only, but if the six attachment holes are standard honda spacing of 70mm apart X 210mm(ish?, cant remember!) then it will fit on most honda racks because thats the honda topbox plate mounting holes.
    my varadero 1000 is the same as the 125, also i believe the TA so probably the AT too. in fact it might not just be honda it maybe an industry standard because my mates suzuki is exactly the same.
    if i see someone at a bike meet suspiciously going around measuring other folks bikes i'll know its you
    Chad's Avatar
    wickford,essex
    hey thats interseting i shal look into itcheers dude
    Steve C's Avatar
    England - landed in Yorkshire
    Quote Originally Posted by 1gear1brake View Post
    Seen here. It says can be fitted with or without existing rack. ...snip
    Gotta say guys, I'm totally impressed with all the stuff you've done! More power to your respective elbows!!!
    !Boris!
    !Boris!!Boris!
    Charlie's Avatar
    Charlie is offline Austin's Son
    Jul 2008
    Garstang
    if this would fit my 07 Varadero 1000 the order will be winging its way today. I will go and measure the bolt hole spacing later then if someone can confirm....
    doh, just realised I am logged in as Charlie. Its Austin here.
    Portland, Dorset
    Quote Originally Posted by Chad View Post
    hope this helps
    chad
    Okay thanks chad.
    In that case, is there a replacement rack available that's able to take a bit more weight than the 10kg that the standard one is rated for?
    Dylan
    Chad's Avatar
    wickford,essex
    Okay thanks chad.
    Dylan
    not that i know of but to be honest when i had my @ i used to put a dam site more that 10kg on the rack anyway
    Lord Vader's Avatar
    Basildon in deepest Essex :-)
    Okay thanks chad.
    Dylan
    Would that apply to Vara's as well????????
    cause i might have put on a bit more than that
    They call him "Ze Quiet one"
    Chad's Avatar
    wickford,essex
    Quote Originally Posted by Lord Vader View Post
    very true my fine tuetonic friend you put ****loads on the vara and the racks basicly the same as the @
  1. Front engine guard (Rugged Roads)
    By mickesjo in forum Africa Twin
    Last Post: 05-12-08, 01:18 PM
  2. Rugged Roads
    By Stormforce8 in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 29-10-08, 01:08 AM
  3. rugged roads??
    By insainwayne in forum Chatter
    Last Post: 04-08-08, 01:35 PM
  4. House extension anyone?
    By Simon in forum Chatter
    Last Post: 22-03-08, 09:22 PM
  5. Rack Extension
    Last Post: 20-03-06, 12:02 PM
