Results 1 to 8 of 8
Thread: Sat Nav help
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Sat Nav help
    A guy on the Rd forum is having problems with his sat nav/bluetooth setup here is his question, it has got most of us on that forum stumped when he said sat nav, most of us stil cannot programme a video recorder
    Guys,
    Apologies if this is slightly off topic for the forum.
    In real life I have a modern bike (CBF1000) to play with along with my RD350A. I use a garmin 550 sat nav with a cardo scala bluetooth headset. Great when its working, however .... I find it works fine for the first ten mins of a journey then it starts crackling and the sound quality deteriorates, it then comes back intermittently but at low vol.
    Does anyone have any experience of these new fangled gadgets?
    Thanks in advance for any suggestions.
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: sat nav help please
    Has he got it hot wired in
    sound like bad connections
    Dont you just love intermittent leccy probs
    take it out of the cradle and use on battery power in the tankbag and try again
    Fully charge the scala then set it to search for connection, then on the sat nav search for headset.
    I removed the connections from my battery when I was fitting something and had a similar problem with the bluetooth on my Autocom, re -established a link and it works fine.
    Re: Sat Nav help
    Quote Originally Posted by Mervinh View Post
    Guys,
    Try recharging the cardo scala bluetooth headset, then reset the garmin and re- establish a connection. if it still does the above then suspect the connections on the headset need cleaning.
    stuart's Avatar
    Jan 2008
    lancashire
    Re: Sat Nav help
    I lost outgoing voice on my Cardio, the problem was one of the pins on the helmet mount had stuck in, I flicked it out with a paper clip and i'ts been fine since
    Lumiya's Avatar
    Ziost
    Re: Sat Nav help
    Merv, please keep the thread to one forum only...
    Mervinh's Avatar
    Nov 2006
    Re: Sat Nav help
    Ok Kymmy did not really know where toput it to be honest
    thanks for the replies so far folks
    merv
    fatowl's Avatar
    May 2006
    Near Exeter, Devon
    Re: Sat Nav help
    Could the crackling be due to interference from the ignition, or charging systems
