Results 1 to 3 of 3
Thread: Radiator Paint
    smallfordsuk is offline Senior Member
    Belfast - Northern Ireland
    Radiator Paint
    Have noticed that the paint on the radiators has started dropping off in chunks - any suggestions on what to use to repaint - did a search but only found that I need to use an Ali primer and then paint - Can I use any paint or is the manifold type stuff better
    Thanks James
    Lutin's Avatar
    Galway
    Re: Radiator Paint
    I don't think that you would need manifold paint - after all, your radiators should never get that hot!
    I just used spray Hammerite on the rads on my TA. The paint was lifting off the bottom tanks of the radiators. I wire brushed the tanks (brass wire brush, mind) then undercoated with the Hammerite "special metals" primer, by brush. Then I masked up the rest of the bike and sprayed the affected areas black, using Satin Black. Job done. Mind you, you cannot reallly see where I've painted without close inspection.
    Typically, I had just emptied and refilled the cooling system before noticing the state of the radiators.
    Re: Radiator Paint
    As above Hammerite is the best paint for the radiator, it is just when the leaking fluid gets under the paint it starts to lift.
  1. A/T Radiator Guards
    By africatwinhullman in forum Africa Twin
    Last Post: 05-05-09, 10:19 PM
  2. Radiator Woes
    By 1gear1brake in forum Mechanical Advice
    Last Post: 12-01-09, 09:34 AM
  3. Paint -- Paint Code -- or Pantone Number?
    By BobA in forum Africa Twin
    Last Post: 21-07-06, 04:43 PM
  4. Radiator Grill
    By BoxtyChamp in forum Transalp
    Last Post: 19-06-06, 05:28 PM
  5. radiator
    By reme59 in forum Africa Twin
    Last Post: 12-05-06, 04:45 AM
