Re: I want to learn how to work on my bike
Get the stuff for a basic service and then one of us will pop buy and stand over you tutting just before you make a mistake and gurgling encouragingly when you get it right (assuming you have made us enough cups of tea).
You need four spark plugs (make sure you have the original Honda plug spanner - or buy one), an oil filter, some oil, a sump washer (buy 20 at a time off ebay or Rugged Roads) and an air filter. If you have not changed the fuel filter for a while get one of those too as you might as well do it while everything is off.
A socket set and some spanners, screwdrivers and Allen keys should do the trick. If you can get one of those oil drain bottles that cost a few quid then it saves using a kitchen baking tray to catch all the cruddy oil.
If you have nowhere to work, then you can come to mine or I am sure a host of others with even better garages and tools.
