If I was to fit brand new OEM carbs to my VFR, would they need the pilot screws set and balancing?![]()
That's what I thought, dang
New O.E.M carb's. . . . . . have you come into a small fortune.
You set the pilots to what the manual says, then pop somewhere to have them fine tuned.
Yen, do you mean the pilot setting fine tuned or have them balanced?![]()
Get them put on I have a set of Vac guages here, we can bal them in a few mins
IM ON THE SAFEHOUSE LIST
Big white LWB Renault Master Van, mobile home for me,Tess and the bikes![]()
Thanks RogI don't have them yet I'm just pondering at the moment.
But if you have the knack of reachning that bloody balance screw on the AT I'd love you to show meI have had gauges on and can tell you they are slightly out, but for the life of me I just couldn't reach that screw.
Ripped of the gauges and went for an industrial-grade sulk.![]()
No sweat, I did mine a short time back, there is a knack to it but just give me a shout when you are ready OK?
Rog
They are balanced by eye on the linkages before/whilst fitting, eneough to run properly. Balancing is just getting them to both open/shut at the same time. The pilot setting will be given as a set number of turns out from fully screwed in. The book will give you the procedure for fine tuning the pilots, but someone with a gas analyser can do it easier. Balancing would be the last part.
