Results 1 to 6 of 6
Thread: mounting box for switch
    Nareef's Avatar
    Nareef is offline Senior Member
    Guildford, UK
    Hi All,
    I’m looking to mount some (waterproof) switches for front and rear fog lights. Some time ago I saw a post where someone had created a handlebar mounted switch box with fuses and common earth point.
    I can’t find it anymore can anyone post me a link?
    Thanks!!
    :0)
    Red (the best colour!) XL700
    Scotoiler, Givi top box & Ring front LED's
    stuart's Avatar
    Jan 2008
    lancashire
    Re: mounting box for switch
    google "CPC" there's something in their catalogue for almost every job,
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    i put a switched live 30A relay/fusebox under the seat of my varadero for accessories, got heated grips, accessory socket and airhorns going through it at the mo.
    it was easier to wire up one switched live from the battery, controlled by a live from the headlight fuse and with an earth up under the dash. the box came from vehiclewiringproducts.co.uk, they have the lot but postage is quite high, unless you get a load of stuff.
    Nareef's Avatar
    Guildford, UK
    Cool, I'll check those out. Thanks.
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by Nareef View Post
    try nippynormans website aswell they do alot of that stuff or go to any electrical wholesaler they sell waterproof boxes in loads of different sizes you can mount your switches in
    GASGAS TXT250 PRO 2006
    largewayround's Avatar
    largewayround is online now Bling Tastic Transalp
    May 2008
    Aberdeen, Bonny Scotland
    You could also try your local maplins, or they have a website also if you do not have a local branch.
  1. mounting panniers
    By fatowl in forum Chatter
    Last Post: 22-09-08, 09:58 PM
  2. Sat Nav Mounting
    By Cabby in forum Mechanical Advice
    Last Post: 27-04-07, 02:00 AM
  3. GPS MOUNTING
    Last Post: 10-07-06, 10:04 AM
  4. GPS Mounting.
    By LaughingBob in forum Chatter
    Last Post: 29-09-05, 09:01 AM
  5. PDA Mounting
    By fewtrees in forum Africa Twin
    Last Post: 03-06-05, 06:57 PM
