well i have now warned Nick of potential incoming of @ calipers,
he seems happy about the idea
Merv
Sorry is this £50 per caliper or for both of them?
Spanner in hand, think mine are still serviceable and this is a bargain
His email say £50 each. If it was both of them, I dare say he'd have a really hard time staying in business. Considering I priced up a new set of seals for both front and back brakes from DSS today and they came in at around £20 this is an absolute bargain! Glad I didn't order the seals earlier.
At least she took them back. You could have ended up with a cupboard full of pairs you'll never use![]()
Hi all
What with work and life in general sorry for not replying sooner to this thread.
As icenian has already posted i can provide a full caliper rebuild [or part rebuild to your requirements] to most brake calipers.
For the twin pots [and the single pot rears] its £49.50 per caliper, thats for the full service, fully stripped, bead blast, powder coat [in a colour of your choice] new seals, stainless pistons, clean and check all threads etc, re-assmbley. If you require the hangers to match [or a different colour] these are £5.00each.
I prefer to recieve the brakes complete and as you remove them from the bike, pad pins, shims, grommets etc.
My stainless bleed nipples are £4.00each, banjos are £2.95each.
I can also supply brake hoses to your supplied lengths, teflon with outer stainless braid, all stainless fittings, various colours available, these are £19.50 per line.
icenian kindly sent me a caliper with the dreaded dust race disease to see if this can be repaired. Im half way through it and will re-post when its finished, until then i cant take on any that have this damage+there will be an additional cost for welding and re-machining, will still work out way cheaper than a new caliper and will be better than new anyway as it will be coated where the original is left bare alloy![]()
