Results 1 to 3 of 3
Thread: Pannier Pucks- How do they work?
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Errmmm.... I´ve seen these, and heard people talking about them, but can someone explain how they fit onto the pannier rails?
    slanty's Avatar
    slanty is offline Senior Member
    Apr 2008
    London
    Re: Pannier Pucks- How do they work?
    It's simple enough... the pucks are the round things you can see here:
    And they fit into the loop of the rack to keep the pannier in position. each puck has a flat bar coming from it that holds the pannier onto the rack. Usually the bottom ones are fixed and point directly down and the top ones are loose so the pannier can be fitted on to the rack and they are then tightened by some kind of manual screw or butterfly nut.
    Here's another pic of a pannier on a bike with the pucks:
    Aug 2008
    Bognor Regis
    Now I get it - Thanks very much
  1. Work
    By Sharribee in forum Chatter
    Last Post: 06-09-08, 05:09 PM
  2. where/how to fit pannier mounting pucks
    By Austin in forum Mechanical Advice
    Last Post: 11-02-08, 05:43 PM
  3. Lucky Sevens Side Stand Pucks
    By matron in forum Past Charity Events
    Last Post: 31-01-08, 10:26 AM
  4. Touratech pannier pucks
    By Stormforce8 in forum Mechanical Advice
    Last Post: 20-02-07, 10:44 AM
  5. Get your pucks out for the lads...
    By MacP in forum Chatter
    Last Post: 13-06-06, 10:45 PM
