Thanks for the tips. Much appreciated. I don't think I'll bother with a relay for this then (though might still fit one for the grips when I get the tank off - the oxford ones I have say they don't need them as it turns them off automatically once the voltage drops below a certain level but I'd rather they just turn off when I turn the ignition off and I'd like to have a relay in there somewhere so I can fit a second power socket that's switched into the cockpit once I finally figure out where to put it).
I don't have a trip meter on the RD04 but I'll have poke around and see if I can find a live and earth when the ignition is on from somewhere else. I'm a bit of a numpty where electrics are concerned but hopefully I'll find somewhere (I've got a multi-meter so I'm guessing if I measure the voltage across the battery, then at other places when the ignition and everything else switched on it should just be a case of finding a wire that matches the voltage on the battery shouldn't it?).
The wires on the fan I seem to remember looking quite handy (plus that's almost never running anyway) so might give those a try first.
