Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Are stainless steel replacement bolts o.k.???
    allyw71's Avatar
    allyw71 is offline Senior Member
    Jul 2008
    cupar fife scotland
    Re: Are stainless steel replacement bolts o.k.???
    I never knew that. Thanks for the tip - will bear that in mind in the future
    An impact driver wouldn't be needed on stainless as they would have Allen or Torx heads, and therefore wouldn't suffer the same probs as the philips heads on the standard bolts
    kiriakost Guest
    I have next to me an impact driver with allen bit ...
    So the point , its not if it can be used .... But to not be used ..
    Because the bolt does not have the same mechanical straight .
    I have destroy an allen stainless steel bolt head , just by the force of my hand.
    And i do not eat lots of spinach ..
    I ended up buying , ultimate quality long allen keys , so to control the force on tightening them up .
  1. Stainless steel oil filter?
    By bikerfromsark in forum Africa Twin
    Last Post: 21-09-11, 07:31 AM
  2. Replacing nuts and bolts with stainless
    Last Post: 14-04-09, 02:27 AM
  3. Stainless Steel nut and bolts
    By Cie in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 11-08-08, 01:55 PM
  4. Are XRV750 headers stainless steel?
    By jfitzsimons in forum Africa Twin
    Last Post: 10-03-06, 05:26 PM
  5. Stainless Steel Exhaust
    By Stormforce8 in forum Africa Twin
    Last Post: 05-01-06, 08:36 PM
