New to all this bike stuff so need a bit of help!
I have a Suzuki dr350 (thought I would post here as it would get more views if thats allowed?!) it would seem that the clutch has gone. Changes into first alright, but when the lever is released it doesn’t really go anyway, it tries to move forward but it wont stall if you stop it. I did just get it going just now and it would ride once moving, but it was still slipping a lot. Worn plates??
Now the only thing is that three days ago it was running, I wouldn’t say 100% as I could feel the clutch slipping a bit, but it would pull away fine and it was stall in first. It seems like overnight something has happened.
And lastly it sounds ok, no knocking noise or grinding anywhere.
So if it was the plates would it go from bad to not working that quickly?
Is this a common problem which is easy to fix??? Im pretty mechanically minded so don’t mind getting my hands dirty!
Cheers,
Tim
