Hello people.
Just wanted to share some info I found.
The best way to see how engines are running, mixture wise, is to use an exhaust gas analyser. Problem is, they arent exactly a tool everyone owns...for obvious reasons....
Well I was doing some research and found an interesting project.
make your own analyser...
All you apparently need is a mulitmeter that can read from 0.1v to 1v and get a Lambda sensor from a car exhaust.
The higher the voltage, the richer the mixture is.
Here is a basic table to work out the mixture:
Voltage: | Air/Fuel Ratio | Rich
0.97v | 12.1:1 | /\
0.88v | 12.7:1 | *
0.78v | 13.2:1 | *
0.69v | 13.8:1 | *
0.59v | 14.4:1 | *
0.49v | 14.9:1 | *
0.39v | 15.4:1 | *
0.30v | 16.0:1 | *
0.20v | 16.5:1 | \/
0.10v | 17.1:1 | Lean
The perfect air to fuel ratio is 14.7:1
so really, you would want to be aiming for 0.49~0.59v on your multimeter...
For the record, I havent tried this yet, but hopefully will when I get a Lambda sensor....could probably pick one up from a scrap yard for a couple of quid....
If anyone tries this, or already has tried it, can you tell me whether it works or worked?
Thanks for listening....(or rather reading :S)
