Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: OIL - Why can't i use a good spec motor oil?
    Lord Stig's Avatar
    May 2004
    West Lothian
    Re: OIL - Why can't i use a good spec motor oil?
    I used to use car oils, but I did get a slip, which I've put down to those friction additives (as Kymmy says, mostly Mo). For the last 80,000 or so (on the same bike) I've used car diesel oil, which is massively cheaper, doesn't contain friction modifiers and has more phosphorus. When you think about it the high compression diesels are far more testing for an oil than most cars, and especially our particular bike engines. It worked for me (and others - search the net), but whether you have the nerve to use it yourself is up to you...
    TRANSPORTER's Avatar
    TRANSPORTER is offline Senior Member
    East Cornwall
    LORD STIG,, I have to agree with you , I myself am using halfords 10/40w semi snth diesel oil in my XR250R, If you look at the XR forum there is a thread on there titled XR4 oil consumption, Now this thread has a great debate on it at the moment about using diesel oils in bikes.
    Ive had no problems using it so far no slippage or wear just good lubrication, changed regulary(damn cant spell).
    Lets hear some more on this subject its interesting.
  4. #13
    Lord Stig's Avatar
    May 2004
    West Lothian
    Nice to hear that TRANSPORTER; it makes a lot more sense especially with proper off-roaders with smaller capacity oil reservoirs amd shorter service intervals. Any idea how many miles you're done with it so far?
  5. #14
    metamorph67's Avatar
    metamorph67 is offline Member
    Jun 2009
    Hastings UK
    I looked in my local Halfords, could find the Semi Synth but it didn't say it was a motorcycle oil, i will look on their site, the screwdriver set is a great tempter though! Lovely grippy handles for my DIY projects, i think i'l go for whatever gets me the drivers LOL! - metamorph67 Thanks for all your input all!
  6. #15
    POTSKI's Avatar
    POTSKI is offline Senior Member
    Mar 2008
    France
    Hi All,
    Been using 10/40 semi-synthetic diesel car oil for years in all my bikes, dry and wet clutch, Z1000, Guzzi Calis, CX 500's XT500's to my latest Transalps, high revers to plodders; never had the slightest problem. Having said that I am a stickler for regularly changing the oil in all my vehicles.
    When I can get it here in the sticks I use Mobil 1 10/40 diesel and would like to use 15/50 when it's stinking hot like it was today, but can never find it.
    Anyway, check these links out, food for thought?
    Potski
    Testing Motorcycle Oil
    All About Motor Oil
    http://www.suzukicavalcade.com/Maintenance/oil_test.htm
  7. #16
    Lord Stig's Avatar
    May 2004
    West Lothian
    Some interesting reading there POTSKI. The phrase 'snake oil' would seem to fit what manufacturers are trying to sell to us in some sense, though the information about shear stresses in relation to the oil being run through our gearboxes suggests regular changes are more critical than in cars.
    Reading around one of the links I found this which seems to be a major manufacturer condoning the use of diesel oils in bike engines - not what I'd expect!
  8. #17
    Zanzibar's Avatar
    Zanzibar is offline Member
    Feb 2009
    European Union
    I've also driven myself madder about oil. I settled on Shell(?) Helix 10-40semi synth petrol car oil. I saw it mentioned on a US thread somewhere.
    Seems ok - no clutch slip. It meets the SG (or SJ?) specs, and has a JASO spec on the can too. It's designed for 1997 engines also.
    I can only hope and see wot's wot. I cant believe it will damage the engine - the clutch is the only issue but loads of guys use car oil it seems.
  1. Spec and Workshop manual for RD03
    By Jim Davis in forum Africa Twin
    Last Post: 26-08-09, 11:04 PM
  2. SJ spec 10/40 oil
    By default in forum Mechanical Advice
    Last Post: 18-06-09, 03:44 PM
  3. ICON MIL-SPEC HiViZ VESTS
    By BIGROG in forum Chatter
    Last Post: 03-01-09, 07:36 AM
  4. Xr400 Overland Spec
    By juniorxr400 in forum For Sale / Wanted
    Last Post: 14-03-08, 09:47 AM
  5. Replies: 4
    Last Post: 21-02-08, 11:57 PM
