Results 1 to 10 of 14
Thread: Ground Anchor vs chain?
    rgarrioch's Avatar
    rgarrioch is offline RetroPhrenologist
    Edinburgh / Opinan (Gairloch)
    Hi,
    With paranoia in the ascendance, poor home security of my beloved @ (d-lock) + mountain bikes (feeble cable locks) has me thinking of putting a ground anchor in my garage, (concrete floor, unable to mount on old brick walls);
    on the other hand, would it be better value threading a decent chain through all the frames, up off the ground with a lock on display on the seat? I'd be nervous of calling attention by fitting anything extra on the garage door too. Fortunately I'm in a reasonably 'secure' area, but really don't want to add to the statistics.
    Thanks for reading, any advice greatly appreciated.
    Cheers,
    Rob.
    "..To The Mountains!!"
    '02 @ RD07, RWB; SW Motech C-Stand, Hammerite-d sub-frame, Re-filled Seat, Supa-Value Honda Freight-Duty Top Box, Givi Pannier Racks + E21 Panniers, MRA Vario Screen, SW Motech Engine Bars
    Genesis Day 06 Road Bike; Revolution Triad 2 HT Mountain Bike; Specialized Pitch Pro FS Mountain Bike
    Male miniature human since December 2010, rendering all other interests redundant
    Re: Ground Anchor vs chain?
    A decent ground anchor is the best deterrent, I had a couple of bikes nicked while they were chained up by the culprits just lifting the whole lot into a van.
    Farky's Avatar
    May 2008
    SW Norfolk
    Have you thought of a garage defender?
    SAS Garage Defender
    If youve got a standard metal frame garage door that flips upwards its the dogs! The Police and a London local council trialed them in some flat garages with brilliant success ages ago, prompted me to get one, had it since as ive got the same issue as you, lots of MTB, Roadbikes and the motorbike.
    One lock does them all, simple to access but hard to break.
    Thing about ground anchors are that you end up chaining things to them, the chain being the weak point for serious thiefs.
    Easy to install but you will need a decent drill as the cement floor needs a wide hole about 2 inches deep - nearly buggered my mates drill!
    2 drill points inside the garage door area and one external - if only the external is tarmac your alright, you need at least the 2 internal points to be concrete.
    rgarrioch's Avatar
    Thanks Stumpy + Farky; definitely having a closer look at that SAS thing - can't see any instructions / installed photos - presume the red 'blocker' goes on the outside, which may attract more attention..?
    Rob.
    Lumiya's Avatar
    Lumiya is online now The Dark One
    Ziost
    No idea if it's any good but M&P in thier latest email has got a chain/anchor combo for less than £20
    1.5m H/D Chain and Lock Offer
    AlanH's Avatar
    Bristol, UK
    Ground anchor and MASSIVE sold secure gold chain gets my vote. If you just chain stuff together it all gets lifted into a van and they sort it out later.
    alpslapper's Avatar
    Essex
    Seconded. I recommend Almax and a Rhino ground anchor. If they get through them, frankly, they deserve to have the bike
    rgarrioch's Avatar
    Thanks for your thoughts + links, ladies & gents; I need to try a few scenarios with all items stored next to each other to find the best position for a ground anchor (that can take a chain from the @ + couple of push-bikes).
    winxp-master's Avatar
    Jan 2008
    Redcar
    I didnt buy my anchor a m8 made it and it's solid and goes about 1.5 feet into the ground i would recommend one and a really good chain. No good having a solid anchor and a chain made out of cinder toffee.
    alpslapper's Avatar
    Essex
    Quote Originally Posted by winxp-master View Post
    You need a damn good lock as well. I use a squire which I'd highly recommend also....
    If you do speak to Almax, you'll probably get Maxine... she's incredibly helpful ... or the husband Alex (I think that's his name).. hence AlMax !! ... they spend ages on the phone advising me of the best locks and chain combos and then gave me a hefty discount. They're not cheap ... but the quality of their stuff is second to none.
  1. Earth/Ground points
    Last Post: 11-05-09, 10:47 PM
  2. TA Chain
    By nigelstuart1973 in forum Transalp
    Last Post: 16-03-09, 01:17 AM
  3. New Chain-guard and Chain Guidance
    By largewayround in forum Transalp
    Last Post: 14-02-09, 08:04 PM
  4. CHAIN FOR AT.
    By ruterovenezuela in forum Africa Twin
    Last Post: 06-04-06, 07:26 PM
  5. Chain(again)
    By mal in forum Africa Twin
    Last Post: 17-03-05, 09:51 AM
