Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Lubing caliper sliders
    antti's Avatar
    antti is offline Senior Member
    Aug 2008
    Southern Finland
    Re: Lubing caliper sliders
    I just putted drive shaft (with molybden) grease in to mine.
    Just happened to be near when needed
    i should have silicon based somewhere, I use it for caliber pistons.
    G/S project bike.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Errr, you havn't been borrowing it from the airframe techs have you?? Used to be my favorite place to get some
    Might have . . . . . might just be a life ex pot that was being chucked out - maybe
    Talking though about copperslip use the spray and not the grease as it goes on thinner, is more slippy and less likely to go gloopy as it's the carrier for the copper that hardens
    I thin copperslip down with some WD40 if I need a thinner coating (Kymmy - PX24 does the same job )
  4. #13
    Lord Stig's Avatar
    May 2004
    West Lothian
    It's worth watching which you use, as GP/LM grease seems to make the rubber boots expand. Once that happens the boots won't fit the grooves, leading to dirt getting in and, eventually, corrosion and seizing. I just use red rubber grease now.
  5. #14
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    I'll try and get some red grease I reckon, as it looks as if I will have to strip the brakes on a regular basis according to a mate who used to off-road a KMX200. The 125 like I owned was a different setup, i gather.
    steveR
    Project Red KMX200
  6. #15
    stageonesimmo's Avatar
    Nov 2006
    Would your choice be due to the fact that you have ample supplies of the stuff like me from our employers?
    A'hem, errr, yes, but due to my recent 'retirement' my supply is running out so any donations are welcome. I've still got a natty Loctite deonstrator tube of copperslip in a pritt-stick type stick applicator - it really is just a copperslip pritt-stick - its so fantastic I haven't had the heart to use it yet!
  7. #16
    steveR's Avatar
    Jan 2006
    Quote Originally Posted by stageonesimmo View Post
    Are you sure it doesn't say Avon on the outside, it sounds more like lip gloss to me!
    steveR
    Project Red KMX200
  8. #17
    Dee Duble Yuh's Avatar
    South Wales, UK
    If you've got a decent motor factors locally, they sell RED GREASE which is used for the slider pins and is compatible with the rubber boots.
    The red grease I've bought recently came in small "ketchup style" sachets rather than a tube or tub they used to sell it in.
    Does the brand matter? For example, should I insist on Castrol, or will Heinz do just as well?
    DW (Dave)
    "Let's ride motorcycles!"
  9. #18
    Nov 2006
    Nope, here it is below in all its un-used pritt-stick-like-copperslip glory......
    How cool is that?!
  1. '93 Transalp front fork sliders
    By Jim Davis in forum Transalp
    Last Post: 30-04-09, 11:58 PM
  2. Using chain wax for lubing cables?
    By Chris.R. in forum Africa Twin
    Last Post: 14-07-08, 06:52 AM
  3. Lubing the throttle twist assembly.....
    Last Post: 22-02-07, 08:07 AM
  4. Clutch cable lubing
    Last Post: 28-11-06, 03:45 PM
  5. aftermarket chain sliders?
    By jfitzsimons in forum Africa Twin
    Last Post: 10-03-06, 08:10 AM
