Results 1 to 5 of 5
Thread: strong overland Panniers
    dazzerrtw's Avatar
    dazzerrtw is offline Senior Member
    Feb 2007
    West Yorkshire
    Craig and I have been looking for a set of pannier's that were strong enough to withstand the extreme use of overlanding.
    There are a few on the market but they tend to cost between £800 to just over £1000
    So we came up with the Idea to buy the part's we needed and make up a set that would be stronger than most on the market .
    They will also be water tight.
    Large enough to carry all our kit .Painted inside to stop all your kit getting dirty.
    We have made a few set's and tested them.
    I must say that they are a very strong and water tight ,with a excellent easy to use quick release mounting Kit, they also have a lock down lid.
    The fitting kit provided will allow them to be mounted on to any looped pannier frame.
    Once we have finished the one's were making for Friend's it may be that we have 3 set's left at the end of July.
    These we will sell on .
    If you would like a set ,our would like to have a close look at them please pm me
    Kjell Lindberg's Avatar
    Sweden
    Re: strong overland Panniers
    Is that 50'cal Ammo boxes?
    c13tay's Avatar
    c13tay is offline Senior Member
    Standish, Lancs
    How much chaps ??
    datsun fan's Avatar
    datsun fan is offline Senior Member
    Jan 2008
    south coast
    How much just for the bungs (mounting kit only) please? and which frames are they designed to fit? Thanks
    1gear1brake's Avatar
    Portland, Dorset
    They look pretty good and I can also vouch for the fact they work well and are fully watertight. I find them a bit heavy being steel but they can't be beat for the money.
  1. how strong?
    By super@ in forum Africa Twin
    Last Post: 01-07-09, 10:29 PM
  2. The Force was even too strong for.......
    Last Post: 31-01-09, 01:29 AM
  3. How strong is kevlar-Jenna/Kymmy
    By Xander in forum Mechanical Advice
    Last Post: 26-06-07, 09:44 PM
  4. HELP You need a strong right hand grip for this !!!
    By Phoenix in forum Africa Twin
    Last Post: 22-09-06, 11:10 AM
