Results 1 to 6 of 6
Thread: Mixing Oils Panic!
    toxster Guest
    Mixing Oils Panic!
    XL125v-06 I'm running on 4 stroke 10/40 semi-synth and have noticed that I'm VERY low on oil and some 30 miles from spare oil.... I do have some 4 stroke 15/50 semi-synth from my scooter. I assume they're different brands as I don't know what's in there already.
    I' m very uncomfortable with the low level (engine was grumbly today) so is it safe for me to top up with 15/50 as
    a) emergency measure (change in next 60 miles)
    b) medium term measure (see me to end of week i.e. 150 miles
    c) not a problem at all - run for another 500 miles....
    Oil and filter change imminent anyway
    Help please...!!!
    AlanH's Avatar
    Bristol, UK
    Re: Mixing Oils Panic!
    If they are both bike oils, the 15/50 should be fine to top it up with - but change it before the weather gets cold.
    chronyx's Avatar
    Surrey, UK
    No problem at all, only a top up amount and both semi-synth.
    Lumiya's Avatar
    Lumiya is online now The Dark One
    Ziost
    Your absolutely fine to mix differnt grades of oil.. You'll just end up with a grade between the two.. Just don't mix mineral and synth as that's when you might get problems with various brands
    toxster Guest
    Woohoo many thanks - total relief.
    Full Oil change this weekend then.
    Thanks again - much appreciated
    NB - yes both bike oils
    toxster Guest
    Thanks again.
    It took half a pint and is running like a dream today.
    Cheers.
  1. Thanks to my employer, Gleaner Oils!
    By africajim in forum Chatter
    Last Post: 03-07-09, 08:53 PM
  2. Mixing Engine Oils?????
    By Ralph in forum Mechanical Advice
    Last Post: 31-12-07, 08:23 PM
  3. oils.........
    By Tjokk in forum Dominator / FMX
    Last Post: 24-11-07, 08:42 PM
  4. mixing tyres
    By barryw33 in forum Wheels, Tyres & Tubes
    Last Post: 25-09-07, 07:31 PM
  5. Pre- MOT panic
    By z-weiser in forum Africa Twin
    Last Post: 26-06-06, 04:06 PM
