Results 1 to 10 of 11
Thread: Crampbusters
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Crampbusters
    A few of you bought Crampbusters for the TLD run.
    How good were they?
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    pale rider's Avatar
    pale rider is offline Senior Member
    Redcar
    Re: Crampbusters
    I used one last year dave, not bad on the motorways for long periods but they become a bit awkward in heavy traffic when you want a degree of slow control..
    but saying that, traveller had one for this years and it looked like it came off much easier than mine did which probably made a huge difference..
    i've never bothered with one since, but i'm sure robster had some kind of screw up wheel on the throttle side bar-end which you screwed up and slightly jammed the throttle a bit so it didn't return by itself you had to physically throttle off... which looked like a much better way of doing it but a bit more complex to fit...
    raymo's Avatar
    aberdeenshire Scotland
    Re: Crampbusters
    put one on for this years TLD.. still got it on..
    it was very good, but had a few 'moments' in slow traffic when I blipped the throttle unexpectedly !!!
    then got into the habit of moving it out the way as I came into a slow section ... just rotate it up and over , as it will move that way as its unwinding of the grip.. prefer it to a throttle lock.....
    hope that helps
    XRV 650R RD03 1989
    The Longest Day Rider 6
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    Re: Crampbusters
    The chosen 'cruise control' for the BMW GS range is either the Kaoko or Wunderlich throttle control.
    I have been using a Vista Cruise Control on my @ for the past couple of years (after seeing Xanders one) - and have recommended them to other @ riders and KTM Adv riders - all are very happy with it.
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Re: Crampbusters
    Thanks everyone I've gone for a bargain throttle cruise control from Jaws Motorcycles who manufacture them.
    BMW R1150GS Cruise Control
    Will report back on how good it is.
    2010 KTM 450 EXC-R
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Re: Crampbusters
    Quote Originally Posted by raymo View Post
    hope that helps
    AOL!!
    I really rate mine and like Raymo, roll it out of the way in town or when I hit some nice nadgery. For under a fiver, well worth a try! As I have a wonky right elbow/arm, it also reduces the strain considerably I have found.
    steveR
    Project Red KMX200
    raymo's Avatar
    Re: Crampbusters
    AOL!!
    Hi Steve... I see 'fools seldom differ' ... best £6 I have spent on the bike ( mine was dear as I bought it at a local dealers )
    really does take the strain of the old wrist and ageing elbow, and can be transfered from bike to bike in a few seconds )))
    cheers
    Raymo
    XRV 650R RD03 1989
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Re: Crampbusters
    Interestingly Motorworks (BMW accessory retailer) told me not to use the Crampbuster on the BMW GS when you have heated grips.
    The heated grip is fatter so he said it was too tight and caused the heating wires in the grip to break when it was moved around.
    So I went for Jaws Cruise Control and around £20. Now fitted.
    2010 KTM 450 EXC-R
    Traveller's Avatar
    Traveller is offline Senior Member
    Nov 2008
    Derby
    Re: Crampbusters
    hope that helps
    As pale rider said, I used one on TLD and it is still on and used. I echo Raymos thoughts entirly. I have standard Honda heated grips and whilst it grips when resting your palm on it as you do when using it you can revolve it backwards through 360 degrees eaisly to re position it if required.
    I have known of these things for a long time but disregarded them as a cheap gimmick. I bid for one that Panrider put up for auction on the basis that if it didnt work I would consign it to the "great idea rubbish in practice" pile of bits that I keep adding to every time I see a must have bit of kit. I will repalce the crampbuster immediatly if ever I loose this one.
    Well worth it for the long boring bits. A little presure on it when you need to increase speed and reduce pressure to reduce. Deninatly reduces fatigue and makes for a more enjoyable ride.
    PS my other bike is a 1800 goldwing that comes as standard with electronic cruise control, I rarley use it because it is such a faff. Technically it is excellent but in the real world I like to be able to make minor throttle adjustments all the time so I much prefer the crampbuster.
    When I see one that fits 1" grips I shall buy it.
    Thats my views added to the pot.
    RWB XRV 750
    Red XRV 750
    GL 1800
    Yellow Honda CT90 Trail
    Red Honda CT90 Trail
    Horses for courses
    Wee Jack's Avatar
    Wee Jack is offline Short Fat Bald Member
    Jul 2006
    An Island Somewhere in the Clyde
    Re: Crampbusters
    Quote Originally Posted by DaveS View Post
    Scottoiler crampbusters come in various diameters (to go over heated grips) and various "paddle" sizes.
    The Crampbuster, Scottoiler Solutions
    2011 Triumph Tiger 800 - "Black Pussy" - MMMM Nice !!!
