Results 1 to 4 of 4
Thread: fao lutin
    ADE THE BLADE's Avatar
    Jan 2009
    up there !
    fao lutin
    Quote:
    Originally Posted by Lutin
    You won't have to wire in a relay for the Stebel Magnum, just replace the original horn with the new one - just two wires.
    That's all I did with mine and have had no problems.
    hi lutin......just got one delivered today...... bit baffled as to where the best place is to fit. ( touching too many " things " in original recess and belly pan ) makes a terrible sound of course. any suggestions / ideas? where did you fit yours after? any pics perhaps? cheers ade
    Lutin's Avatar
    Galway
    Re: fao lutin
    There ya go -
    Fitting Stebel Magnum to 2004 Transalp
    With all the piccies as well.
    The trick is the custom made bracket, which should not be too hard to replicate.
    Jan 2009
    up there !
    Re: fao lutin
    hey lutin... what a mate. all makes sense now. didnt remove horn bracket for a start. otherwise very easy to follow. kept thinking a small twist was needed for it to clear pan etc. already made wire extenders. will give it a go in next couple of days. will knock up bracket tomorrow. thanks again for detailed instructions
    Lutin's Avatar
    Galway
    Re: fao lutin
    No problem mate. Hope you get it sorted.
  1. To Lutin
    By brownetara in forum Travel
    Last Post: 16-06-09, 10:42 AM
