just found this;
Motorcycle Single Wheel Trailer Law in the UK
In the UK in 1984 it became legal to tow a trailer behind a motorcycle. The rules governing the use of trailers behind motorcycles is set out in the Road Vehicles (Construction and Use) Regulations 1986. As far as motorcycle trailers towed behind a motorcycle are concerned the law is basically:-
- The towing motorcycle must exceed 125 cc engine capacity.
- The trailer has an overall width not exceeding 1.00m
- The distance between the rear axle of the motorcycle and the rearmost part of the trailer must not exceed 2.5m.
- The Motorcycle must be clearly and indelibly marked with it’s kerbside weight.
- The Maximum towed weight, including the trailer and it’s load must not exceed 150 Kg (330 lb) or two thirds of the motorcycles kerbside weight, whichever is the least.
- The UK speed limit is 60 mph on Motorways and dual carriageways and 50 mph on all other roads unless a lesser limit is in force.
There are other regulations regarding lighting (The Road Vehicles Lighting Regulations 1989) specifying the number, type and spacing of lights and reflectors and the particular "E" marks they should all carry to be fully road legal, trailer bulb failure warning and regulations covering the actual construction of the trailer (The Road Vehicles (Construction and Use) Regulations 1986)
Towing a motorcycle trailer abroad is not a problem as visitor laws apply - basically the trailer being towed must be legal in the owners home country.
2.5m from the rear axle to the back of the trailer, pushing it for a canoe? if you cant live with an inflatable like jenna says then the only option will be some crazy sidecar like that ural with the boat on it.
