Results 1 to 10 of 11
Thread: Cutting Perspex
    barftone's Avatar
    Apr 2005
    Bath, England
    Cutting Perspex
    Help tech heads. Whats the cleanest way of cutting a sheet of perspex. I'm going to cut a small nose fairing out for the DRZ but wondered what gave the best finish. Heat applied to the edges after cutting??
    Sohoeasy's Avatar
    Sohoeasy is offline Stone Chiller.
    May 2005
    Westminster London
    Re: Cutting Perspex
    Tone ! This company were in England back in the seventies. ( I got some off-cuts for my old Matchless sidecar screen )They seem to have moved to Ireland. If you give them a bell, with some sort of bull story about buying in bulk they may well give you some tech info .... If I remember right I bent my screen up, in a bath of boiling water. .................http://www.williamcox.ie/
    Here we Go!!!!!!!!!!!!!!!!!
    mad4it028 is offline Senior Member
    Aug 2009
    peterborough
    Re: Cutting Perspex
    i used to work for a firm that made the perspex screens for icerinks we cut then to size on site with a router hth
    AlanH's Avatar
    Bristol, UK
    Re: Cutting Perspex
    Stick masking tape where you're going to cut and use a jigsaw with a fine toothed blade on a high speed. Let it cut at a gentle pace otherwise it'll melt and weld itself into a gloopy mess. Also important is to make sure you keep pressure on the sheet so it doesn't vibrate against the bench as that can crack it.
    That's how I've always done it anyway. I'm sure there's probably a proper way to do it but that works for me.
    Bolton, Lancs.
    Re: Cutting Perspex
    Easiest way i found is use a small angle grinder with a really thin cutting disc, then production paper on a block to finish to shape, then fine abrasive paper for final finish. . . . thats how i did the short screen for my transalp.
    chalky4's Avatar
    Nov 2008
    Newport Pagnell
    Re: Cutting Perspex
    Quote Originally Posted by barftone View Post
    I've just finished cutting some to fit out side of back door to stop dogs scratching wood when they want to get back in, used a 9" angle grinder, I've cut before using jig saw but it heat welded its self together behind the cut. Both times on thicker stuff than you would be using for your fairing so don't know how either would do perform on thin perspex. Good luck and don't forget picture of finished job.
    Lumiya's Avatar
    Ziost
    Re: Cutting Perspex
    Some very wide masking tape on noth sides and a very fine blade or router.. and take it slow, the faster you go the more heat generated and you'll end up with discolored perspex at the edges
    XR Mad's Avatar
    XR Mad is offline Senior Member
    South wales
    Re: Cutting Perspex
    disc cutter works fine with a thin disc as said before. I used a belt sander clamped upside down in a vice to clean up the edges
    Lumiya's Avatar
    Ziost
    Re: Cutting Perspex
    Disk cutters (we sometimes use a fine stainless disc) is great for straight lines but no good for curves.. You have to be really carefull with the heat issue
    barftone's Avatar
    Apr 2005
    Bath, England
    Re: Cutting Perspex
    Thankyou team. Come up trumps again.
  1. cutting out
    By Windmill John in forum Dominator / FMX
    Last Post: 29-10-08, 04:46 PM
  2. Cutting Out
    By Windmill John in forum XR
    Last Post: 23-10-08, 10:19 PM
  3. Cutting Out ??
    By SHARPY in forum Varadero
    Last Post: 19-02-08, 12:44 PM
  4. cutting out
    By jabba in forum Varadero
    Last Post: 08-06-07, 12:11 PM
  5. Anyone for @ Key Cutting
    By Yeti in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 04-05-06, 04:47 PM
