Results 1 to 5 of 5
Thread: Compression tester
    XRV freak is offline Member
    Sep 2008
    Slovenia
    Compression tester
    Hi,
    I'm planing to buy compression tester for testing compression on my motorbikes. I entered this keyword in E-bay and get 256 results with price range from 1 GBP to 500GBP
    compression tester, Vehicle Parts Accessories, Business, Office Industrial, leak down tester items at low prices on eBay.co.uk
    Which one to take. Is compression tester for aprx. 30 pounds any good. What to look for when buying. Is there any specific thing on which should I pay my attention.
    Regards
    Gregor
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Re: Compression tester
    i cant comment on the quality of the kit without having it in my hand, but i can comment on compression testers having owned and used a few.
    dont make the mistake of only getting a 2 gauge tester because you have a 1 or 2 cylinder bike, thats now but what about in the future? a 4 gauge will only cost a few quid more and can do 99% of bikes. (it is possible to sync 4 carbs with even a single gauge but it takes hours and really isnt worth the hassle!)
    when you get the tester test the gauges for consistancy and leaks by putting each gauge on the same test outlet one by one and make sure they all read the same. if not, its worthless and send it back.
    a haynes/clymer/dealer manual will have compressiion readings in it
    jasonbc's Avatar
    Camborne, Cornwall
    I think your confused with Vacuum guages for balancing carbs
    GASGAS TXT250 PRO 2006
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    aha, you spotted the deliberate mistake
    buggering ******** what a ****
    Sep 2008
    Slovenia
    It happens
    Well vacuum guages for balancing carbs is next investment so thanks anyway for the tip
  1. Wanted: XR 250 De-compression cable.
    By Wil 1100 in forum For Sale / Wanted
    Last Post: 17-03-09, 11:11 PM
  2. £2 Lidl Battery/Alternator LED tester
    By Zenarchy in forum Mechanical Advice
    Last Post: 25-02-09, 12:53 AM
  3. Fmx compression check.
    By robertas in forum Dominator / FMX
    Last Post: 29-07-08, 09:41 AM
  4. mot tester manual/notes
    Last Post: 31-08-06, 12:52 PM
