Results 1 to 9 of 9
Thread: heated grip problem
    pale rider's Avatar
    pale rider is offline Senior Member
    Redcar
    heated grip problem
    would you credit it.... with winter virtually on the doorstep me left hand oxford heated grip has stopped working.
    where do i start troubleshooting has anyone had any breakthru's with them???
    R0vers's Avatar
    Mar 2007
    South London/Somerset
    Re: heated grip problem
    contact them direclty and they SHOULD send out a replacement...
    im on about my 5th set from them.... ill pm you with their email address...
    TLD2008 15.41
    Boris's Avatar
    Boris is online now Wrinkled member
    Oct 2006
    Edinburgh, Scotland
    Swap the cables over as they come out the controller towards the grips. At least that will give you an indication as to whether its the controller or the actual grip that's at fault. I know someone that 'may' have a spare (older style) controller if its that.
    You can buy spare grips from Oxford but they are expensive.
    I'm on the Safe House List
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Don't the oxfords have a lifetime garantee/ or does it depend on the model/
    I sent my controller back through busters and they sent me a brand new digital controller within the week.
    pale rider's Avatar
    Redcar
    cheers for the advice guys... its always on the level.. i've got the older type dial control on the bike it was already fitted i actually prefer those type as they can be switched on or off or adjusted safely while your moving
    i'll try what you said boris as it will narrow the fault down to either the controller or the actual grip itself which would be preferable
    and thanks for the pm rover i might contact them and see if they can just send me a replacement grip
    a lifetime gaurantee would be handy ritch, but everytime i've tried to use that they usually manage to get out of it somehow(it was the end of the grip's life etc)
    If you buy a new set of grips you could connect them to the controller and if it is broken use the new one, just make sure you have one LFET hand and one RIGHT hand grip.
    pale rider's Avatar
    Redcar
    i actually have another set that i fitted myself on my other bike( a teapot)
    they are the newer LED type but the whole kit is under £50 so maybe i can just get another grip from the address that rover sent me
    i would have had a look tonight but something else came up....
    RodYork's Avatar
    RodYork is offline Senior Member
    Jul 2009
    York
    Sorry to hijack the post, but this reminded me I must get some heated grips on the @. I have fitted them to other bikes without difficulty, but is there a switched live anyone recommends using? . The grips I will be using are the "nob" style Oxforde grips- so don't want to be installed directly from the battery- unlike the new ones
    Thanks in advance
    trophydave's Avatar
    trophydave is offline Senior Member
    Feb 2007
    Nottingham
    Rod,I used the supply to the rear brake switch for mine.That way you have a short run from the battery to a relay under the right hand side cover.
    Rust never sleeps
  1. Help.. Throttle Grip Problem!
    By Pondlife in forum Transalp
    Last Post: 11-09-09, 12:40 PM
  2. Oxford Heated Grip Control Unit
    By LUNLUNZAI in forum Mechanical Advice
    Last Post: 10-11-08, 08:27 PM
  3. How do you stick a heated grip to the throttle body?
    By Austin in forum Mechanical Advice
    Last Post: 12-11-07, 01:56 PM
  4. Grip Help
    By shack in forum Africa Twin
    Last Post: 28-06-07, 09:31 AM
  5. Heated Grip parts
    By RainMan in forum Transalp
    Last Post: 16-02-07, 01:51 PM
