I'm trying to fit heated grips, GPS, socket etc through a relay/distribution block system and outlined on this website..
.: Distribution Block / Powered Relay | Canyon Chasers Motorcycle Sport Touring :.
I bought all the parts he described to the T. (links at bottom of page)..
His instruction say that you need a postive side and a negative side of the distribution block (makes sense) but what confuses me is, the top and bottom of that block are connected.
SOOOO, if you use the jumpers, the whole block is all connected. Not seperate as instructed.
On all distribution blocks, the screws connect a circuit (eg top left screw is connected to bottom left screw).
So, is this diagram correct.. Is the top positive circuit seperate from the bottom negative circuit. I cant see how it can be using the parts described.
If you lay a jumper strip accross the screws, the whole block will be connected... ????
