Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 97
Thread: Rear light LED on Givi Top Box
    Lumiya's Avatar
    Ziost
    Re: Rear light LED on Givi Top Box
    If you're using red LED's then no need for a lens
    Severe Marmalade Guest
    Spada do a back box with a built in High level brake light. It is branded Spada but built by Givi ( Givi's daughter owns Spada ) which begs the question
    " Are parts interchangeable "?.
    Here is a Spada SP42 box fitted to Dads Varadero.
    http://www.xrv.org.uk/photopost/data...d_sods_004.jpg
    The box was bought locally from Bike Gear and I know a company called Feridax do the light as an accessory
    Spada SP29 / SP42 Brake Light - Feridax.com
    If the parts are indeed interchangeable then in the words of Rhodri Owen "Sorted"
    HTH?
    J.
  4. #13
    Lutin's Avatar
    Galway
    Ah, but that would spoil the look!
    However, I did toy with the idea of ditching the reflector altogether and just cramming a whole load of LEDs together into the rectangular space available.
    Connecting them up in a combination of series and parallel, I would still be no where near 1 Amp total current. Might still do this.
    Wish I had the facilities to make my own PCBs. Drawing them up is no problem as there's plenty of PCB CAD packages available - KiCAD, Eagle etc etc.
  5. #14
    Lutin's Avatar
    Galway
    Quote Originally Posted by Severe Marmalade View Post
    http://www.xrv.org.uk/photopost/data/500/medium/Odds_and_sods_004.jpg
    HTH?
    J.
    The problem with the connector having to take the 2 Amp current would still persist though, and it is this that causes all the problems.
  6. #15
    Just take it from the brake light as is the case with dad's
    J.
  7. #16
    Lumiya's Avatar
    Ziost
    www.techniks.com Although they are dear you can get the paper in other places like ebay and the chemical etch/boards either online or maplins
  8. #17
    rssenna's Avatar
    rssenna is offline Member
    Jan 2008
    SW Scotland
    Just remember that it's illegal to have a flashing red light on a motorcycle
    Kymmy - it is illegal to have a flashing red light on a push bike as well, which begs the question why do most bike lights come with a flashing option? Certainly on a push bike I have not heard of anybody getting done by police as increasing visibility is seen as a prioity. Some police may take different view of a motorbike thou. Can still be used in constant mode.
    I actually have a blue light on my push bike that has a flashing option, I only put it on constant thou as do not want to tempt getting pulled. Putting one on the front and flashing would increase visability though, don't think I would be cut up much either!
  9. #18
    Traveller's Avatar
    Traveller is offline Senior Member
    Nov 2008
    Derby
    This is an interesting topic. I have used veroboard in the past to make replacement "Bulbs" out of clusters of LED's. The veroboard supports the resistors as well as the LED's. Now 12v LED bulbs are commercially available at reasonable prices there are other options to the DIY route.
    As Kymmy points out, there is no need for a lens if you use a coloured LED as it is waterproof.
    I have found the LED replacement heads for the Halogen downlighters to be a good cheap source of cheap 12v LED lights.
    The big win with these things is the low power requirement. Kymmys idea of driving them with the inductance loops would be good too. No connectors to mess with and get crudded up.
    RWB XRV 750
    Red XRV 750
    GL 1800
    Yellow Honda CT90 Trail
    Red Honda CT90 Trail
    Horses for courses
  10. #19
    Lumiya's Avatar
    Ziost
    Quote Originally Posted by rssenna View Post
    It's only illegal to have a red flashing light on a pushbike if it's fitted to the push bike, if it's clipped on a person then that's fine though I'm not sure if the pushbike rule got recinded in the last few years
    Motor vehicles though have very different rules and lights (and reflectors) attached to the vehicles are governed under rules designed for emergency vehicles.. Red lights can only be rear facing and not flashing, any other usage is for emergency vehicle only and the same for green and blue.. which also can't be used for rear.
  11. #20
    Lutin's Avatar
    Galway
    Quote Originally Posted by Traveller View Post
    Oh, don't you worry - there's veroboard, LEDs, resistors and goodness knows what around here.
    I used Veroboard to mount the LEDs that I have now as the original PCB did not lend itself easily to what I wanted to do - put two pairs of three LEDs in series.
    The LED replacements for downlighters is an idea though, but they would all be white and some of them can be very high current - which was what I was trying to get away from in the first place. Hmmm, got me thinking again though.
    As for the inductance thing, this is going to need thinking about. The problem being the variable frequency from the alternator due, of course, to varying engine speed. So, any coils need to be efficient over quite a frequency range of, say, 25 Hz (1500 rpm) to 142 Hz (8500 rpm). Possible, but would need careful coil design.
  1. Rear Fog Light
    By sadpsych in forum Transalp
    Last Post: 26-05-09, 07:05 PM
  2. BMW rear light?
    By Swifty in forum BMW
    Last Post: 16-04-09, 06:37 PM
  3. Replies: 21
    Last Post: 20-12-08, 10:17 AM
  4. LED rear light.... Have you got one ??
    By sharms1101 in forum Transalp
    Last Post: 22-10-08, 04:55 PM
  5. Givi e97 Top Box Brake Light Wiring
    By slanty in forum Africa Twin
    Last Post: 05-06-08, 11:57 AM
