Re: Rear light LED on Givi Top Box
Holy LEDs batman .... theyve confused the hell out of me!
Possibly some confusion on the location of my reflector as mine wraps around the rear and sides of the box as a constant as opposed to the brake light idea that Givi supply which sits in the middle above the opening mech.
Glad I asked about the Givi brake light though, will give it a miss if its pants, not suprised really.
Considering the idea of a high vis strip of material as a simple immediate solution and then maybe set about adapting some bicycle lights into the reflector powered by batteries.... only looking for nighttime use really.
Now if one of you could work out how to create a strip of led's about 18inches long that will fit behind the reflector and power from a small battery set... im sorted!
