Re: Rear light LED on Givi Top Box
Ah no, sorry it doesn't work like that. If only it did.
Any LED will need a resistor to limit the current through it, in this case to a maximum of 20 mA.
Putting an LED straight across a supply will destroy, or at least permanently damage, the LED.
I suppose that you could get away with 5 LEDs in series, so your current limiting resistor would then need to be (2 Volts / 20 mA) 100 Ohms. Although this is risking the LEDs not working with the supply much below 12 Volts - but then again if the supply is much below 12 Volts the last thing you'll be worried about is the LEDs not working!
Sorry, I should have made this point earlier. It's another case of there being no free lunch.
