Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 38
Thread: sigg fuel bottle or not?
  1. #21
    davsato's Avatar
    Aug 2007
    Fareham, Hants
    Re: sigg fuel bottle or not?
    no idea mate, being foreign they are bound to be that new fangled metroid rubbish.
    MarkR's Avatar
    MarkR is offline Brrrummm!
    Mar 2007
    High Peak, Derbyshire
    Never mind the quality feel the width!
    IF, Swiss legislation prevents the carrying of fuel in portable containers this will mean that the traditional SIGG bottles will not be manufactured and sold as a fuel bottle.
    The pickies below show my MSR fuel bottle and a SIGG bottle purchased from Overland a few months ago. Clearly on the bottom of the SIGG bottle it is only for food and hot liquids but not fuel (petrol).
    To comply with the Swiss legislation, it would appear that SIGG engineers have redesigned the stopper by using a non-neoprene sealing gasket (white in the picture) with a fail-safe channel running up the screwed area of the stopper. Tampering or removing the white gasket will allow any fluids to bypass any new gasket and cause leaking.
    The solution is to replace the SIGG stopper with a MSR stopper, as used on MSR Fuel bottles, for about £2. Job Done. I obtained my stoppers from Needle Sports, Keswick, Cumbria.
    Mark
    Hope this clears things up.
    "It's all very, very simple and easy to do!"
    2011 BMW G650GS (White/Grey)
    TLD 2008 JOG-LE - 16h20m - F650GS
    G3XYS - IBA #40715
    http://www.ecclespike.org.uk/index.html
  4. #23
    AlanH's Avatar
    Bristol, UK
    Quote Originally Posted by MarkR View Post
    So the guy working for SIGG in this thread I posted a link to is wrong when he says this...
    The SIGG bottle should only be used as a WATER BOTTLE
    It has a proprietary (sp) liner on the inside as well which may disolve when used with fuel."
    and this...
    SIGG has become very popular in the US this year do the concerns related to drinking from Poly Carbonate bottles which may leach BPA. The SIGGs liner is inert and non leaching, is flexible and will not crack or chip if the bottle is dented. IT SHOULD ONLY BE USED AS A WATER BOTTLE
    I can't imagine dissolved plastic being much good for an internal combustion engine so is your info source 100% correct?
  5. #24
    MarkR's Avatar
    Mar 2007
    'The' solution is My solution. On further inspection of the inside of the SIGG bottle, there appears to be a covering over the aluminium as compared to the MSR bottle. If petrol dissolves this unidentified covering, it can only be microns thin, I will fill both of my two SIGGs with petrol, dissolve away the 'liner' and use the fuel in my lawn mower(s). Both my SIGGs are marked for 'Fuel Only'. I have filled one SIGG bottle half-full to observe a tide-line which will appear between a dissolved area and an unaffected area. What's all the fuss about? Up date to follow.
    Mark
    G3XYS - IBA #40715
  6. #25
    Critch's Avatar
    Critch is offline Hi SuperNintendo Chalmers
    May 2007
    Bury ,Manchester,Uk
    wow and heres me thinking they were just Parafin bottles !
    never considered using them for petrol
  7. #26
    AlanH's Avatar
    Bristol, UK
    What's all the fuss about? I was re-emphasising what the SIGG employee said. Your post gave the impression that the only issue was the stopper and once that was changed, "job done". Anyone coming to the thread late would have missed the bit about the lining. I don't know how much dissolved plastic is acceptable for use in an internal combustion engine - but I'd certainly like it to be as close to zero as possible.
    If the plastic layer can be dissolved out of the bottle before use then that may well be job done but I think I'd just get an MSR in the first place.
  8. #27
    tramp's Avatar
    Feb 2009
    hampshire/Fareham
    yeh ,
    your correct Alan h ,
    from the preverbial mouth of "sigg":
    the old now discountinued fuel bottles had a different seal and top.
    They were unlined- unlike new food/water bottles.
    the msr are unlined and have a fuel "safe" lid and seal [neoprene]
    the primus have a coating also
    the trianga ones are plastic of a grade made to withstand preesure
    **** basically the lining in the sigg was added to stop the food/water tasting funny but it does breakdown over time [how long they wont say]
    but as your using it for a purpose not designed for you cant sue them [sigg] if it melts or nackers your stoves.
    I have gone for a new MSR with child proof top and spare seal , thats my choice.
    just didn`t want anyone buying a duff bottle your choice
  9. #28
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Quote Originally Posted by Bluff View Post
    I appreciate the thread was about Sigg but Trangia do fuel bottles for their stoves, they are very strong plastic with a pourer / nozzle. Now I come to think of it MSR do fuel bottles to, and Primus for that matter.
    Mr Cheapskate here uses a brake fluid container for carrying fuel for his Coleman! Seems fine with no deterioation of the bottle after 6 months with Aspen petrol in it!
    steveR
    Project Red KMX200
  10. #29
    DRLANER's Avatar
    DRLANER is offline Do you have any cheese?
    Here, There, Everywhere!! (But mostly Here)
    Don't know what all the fuss is about, I have been using 4, 1 ltr aluminium bottles that I bought from a camping shop, all 4 cost me £20 and I have them strapped to the back of my panniers!
    They don't leak at all and I have used the fuel in them many times in the bike and had no problems.
    Cheap solution and it works perfectly!
  11. #30
    Boris's Avatar
    Boris is online now Wrinkled member
    Oct 2006
    Edinburgh, Scotland
    I was given a couple of MountainLife aluminium bottles for christmas and by way of experiment I filled one up with fuel and left it inverted. So far no leaks and the stopper and seal show no sign of attack. The were cheapies from Mountain Warehouse and were about £10 for two (buy on get one free).
    I'm on the Safe House List
  1. Wanted: PUB CO2 Gas bottle please.
    By Grizz in forum For Sale / Wanted
    Last Post: 17-05-09, 02:16 PM
  2. Transalp spare fuel bottle mod.
    By POTSKI in forum Transalp
    Last Post: 01-04-09, 06:36 PM
  3. Wanted: RDO3 coolant expansion bottle
    By Lam in forum For Sale / Wanted
    Last Post: 05-07-08, 01:17 PM
  4. Anyone found my bottle ???
    By Hosay in forum Chatter
    Last Post: 21-08-07, 03:30 PM
  5. How to clean the coolant reservoir bottle ?
    Last Post: 19-11-06, 10:20 AM
