Results 1 to 10 of 19
Thread: Oxford Heated grips
    Frad's Avatar
    Frad is online now Senior Member
    May 2008
    Cheshire
    Oxford Heated grips
    I have a set of Oxford heated grips which have worked great up til last weekend when they wont switch on straight away then they go to full power, after about an hour they worked fine again, but now they are playing up again
    Please help
    they are the push button model + and - ones
    thanks Frad
    XL 1000 VA '09 In Burnt Orange Honda Top Box, Main stand, Scottoiler, grips, ARDcases.
    XL650 '06 In Black sold
    Elizabeth Kubler-Ross: Quotes: Adventure
    It is only when we truly know and understand that we have a limited time on earth and that we have no way of knowing when our time is up that we will begin to live each day to the fullest, as if it were the only one we had.
    Re: Oxford Heated grips
    I had a set of those and have just had to change to the newer type as the controller went wrong.
    Frad's Avatar
    May 2008
    Cheshire
    Did they replace it or did it cost you ?
    Austin's Avatar
    GARSTANG
    sounds like its the switch. The "-" button on mine sticks sometimes and after reducing the heat they often switch off totally. I need to fiddle with the button to clear it before they wil switch on again. Your + switch could be sticking when you switch it on, hence the switch straight to max.
    Bet it got wet in all that welsh rain the other week.
    Quote Originally Posted by Frad View Post
    I bought a new set of grips complete, kept the other grips for spares.
    Frad's Avatar
    May 2008
    Cheshire
    But it looks a sealed unit ?
    do you just keep pressing it then ?
    you dont think its a charging issue, they are wired to the ignition.
    Treadtrader's Avatar
    Treadtrader is offline White van man
    Jul 2007
    Warwickshire
    I bought a set of these off fleebay for my pals Superten, the same problem occured after a month or so.
    Read somewhere on the net that Oxford had problems with early units.
    I contacted Oxford by phone but they showed little interest and told me to contact retailer.
    The retailer asked me to return the unit and after a couple of weeks a new unit arrived.
    I have the same unit on my AT with no problems.
    Austin's Avatar
    GARSTANG
    I was only joking about the rain
    If you press the switches you can feel the contacts move and a very slight click (gloves off for this). When mine goes wrong the - switch feels "dead", a bit wooden, like its not doing anything. Pressing it a few times usually seems to make it work normally again and then the grips will switch on. Leaving it for 5 or 10 minutes usually works too.
    I had a problem with the old rotary switch as well. Couldn't find the receipt so the dealer wouldn't help. Oxford were useless and said not their problem take it to the dealer. I bought a replacement set just for the switch as it was only about £10 more than buying just the switch. I have since had that switch replaced - this time via the dealer and took about 2 weeks as per treadtrader. I have also replaced both grips since.
    So that makes my grips a bit like Trigger's broom in Only Fools and Horses. I have only ever had one set, but have had 3 switches and 2 sets of handgrips.
    Frad's Avatar
    May 2008
    Cheshire
    Cheers all for the replies
    think I will have a lay with them and root out the reciept at the same time
    digitalcaptive's Avatar
    Apr 2008
    Surely your iphone has and app for this
    I'm on the Safe House List
  1. Oxford Heated Grips vs Motrax Headed Grips
    By Wold Rider in forum Africa Twin
    Last Post: 13-12-08, 09:58 PM
  2. Oxford Heated Grips
    By 1gear1brake in forum Mechanical Advice
    Last Post: 03-09-08, 02:17 PM
  3. Oxford heated grips...
    By Grooverider in forum Mechanical Advice
    Last Post: 03-02-08, 11:22 AM
  4. Heated Grips... Oxford
    Last Post: 29-11-06, 06:02 PM
  5. Oxford heated grips
    By Patrick in forum Transalp
    Last Post: 03-03-06, 12:04 AM
