Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: How long to trickle charge
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: How long to trickle charge
    Bear in mind, some sealed batteries, once dead, are truly dead!! They only take complete discharging so many times before they give up, and I found this out to my own expense!
    I have the problem of no power to my shed so leave mine connected to a solar charger, it puts just enough back in the battery to keep it charged.
    As for the mains powered chargers I have one specifically for a bike and one for a car.
    The car charger is too powerful for the bike battery so I use the Selmar bike charger, it is rated at 500 mA DC, with a switch for 6 or 12 Volts .
  1. advice solar trickle charger
    By jamie92j in forum Varadero
    Last Post: 30-09-09, 12:02 PM
  2. Obama's now in charge
    By jasonbc in forum Chatter
    Last Post: 21-01-09, 03:46 AM
  3. No Charge for Manchester
    By Critch in forum Chatter
    Last Post: 12-12-08, 04:10 PM
  4. Replies: 0
    Last Post: 02-11-08, 09:56 AM
  5. Dyna Charge Monitor
    By GSPD750 in forum Africa Twin
    Last Post: 01-01-70, 10:28 AM
