Results 1 to 10 of 13
Thread: Ham Radio On Bikes
    Rondini is offline Member
    Jun 2009
    Bedfordshire
    Ham Radio On Bikes
    Any Hams on here , I'm looking for info on radio mounting
    Ron
    iainnic's Avatar
    Jul 2008
    Lancashire
    Re: Ham Radio On Bikes
    what are you looking to mount and on what ?
    Iain
    "Annie" - 1200 GSA 30 Anniversary Colours
    Jun 2009
    Bedfordshire
    I'm looking to mount a 2 meter handheld radio, possibly through an Intaride RP1 kit on my Transalp 600 (96)
    Ron
    Lumiya's Avatar
    Ziost
    As there's a lot of different radios it might be better to suggest which one especially as they all mount differently
    Thread moved to BIKE TECH
    Lumiya's Avatar
    Ziost
    The most efficient way though is to either do a semi-open faced mount which the radio sits in and a velcro strap over the top, or if you want a waterproof mount then there are a few boxes/bags that can be handlebar/frame mounted..
    iainnic's Avatar
    Jul 2008
    Lancashire
    I've not seen that model of intercom, but it looks similar to Autocom from the web site, so should be straight forward. You need to make sure you handheld switches the TX and TX, as most intercoms run a "high / low" switch, and some of the new radios are using resistance change to switch as the sets become more "computer with a radio engine" based. Certainly some of the newer commercial kit I've seen is moving this way. Most ham sets do just use a basic PTT switch so you should be OK.
    The 600 won't be affected too much by RF interference - the 700 worries me even with a PMR446 set (very low power) , so its on the back of the bike ! The average HAM or commercial hand set will run 5 watts.
    The other option is to use Bluetooth. There's a pretty universal box from RPF-Comms called the Talksafe Ranger (www.rpf-comms.com) and they have leads for most kit. There's a couple of articles re bikes on the web with these.
    As for mounting the radio, there's a number of people who make Aquapack type bags for protection. I've seen some where an external antenna has been mounted on the bike, and the radio put in the tail pack or tank bag as it doesn't need to be vertical then.
    Iain
    Jun 2009
    Bedfordshire
    Thanks for the info guys, I've Had the Intaride 446 system for 5 years now with ( touch wood ) no problems, I had it mounted on a Diversion 900 previously, whichever handheld I end up with will probably be mounted on a Ram mount inside a Marine grade waterproof sealed cover. as to the antenna make and siting, I will have to get more info.
    Ron
    I would rather eat the Ham, it would be better than making a radio out of it.
    I'll get my Coat.
    jarl's Avatar
    jarl is offline Senior Member
    Apr 2009
    Bath
    Not ham, but is there any way to link 2 bluetooth devices to each other to get comms?
    Quote Originally Posted by jarl View Post
    If you set them to search they should both find each other and link.
  1. PMR radio without PMT
    By Snaphappy in forum Mechanical Advice
    Last Post: 26-04-09, 10:42 PM
  2. Radio
    By Robadero47 in forum Varadero
    Last Post: 24-10-08, 02:15 PM
  3. XRV live on the BBC Radio
    Last Post: 18-07-08, 09:59 PM
  4. radio two
    By barbarabainbridge in forum Chatter
    Last Post: 01-03-08, 12:40 AM
  5. MP3 Radio
    By Ralphie in forum Mechanical Advice
    Last Post: 08-02-07, 05:41 PM
