Results 1 to 3 of 3
Thread: HID HELP!
    jamie92j's Avatar
    jamie92j is offline bike nut
    Aug 2008
    The 'Shire'
    HID HELP!
    hi got a hid kit, no instructions
    does anyone have a wiring diagram or some more info on how they fit?
    thanks
    everything is OK
    http://rt.com/
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Re: HID HELP!
    Depends what system you bought,some just plug into the original bulb socket and off you go,some only use the original for power to the relay to switch it on and draw power from a fresh feed from the battery you have to run to the relay.
    Did the kit come with a relay? If not just check the wiring,there should be two earth and a live if it needs a relay or just a plug in plug with spades if you need to just plug and go.
    Re: HID HELP!
    Depending on type, mine came with everything and I just had to connect a positive and a negative to the battery and plug the headlight feed into the supplied loom and it was set.
